1952-59 Ford Brakes For '53 Customline
Discussion in 'Off Topic Hot Rods & Customs' started by Pheaton193, Jun 25, 2016.
  1. Pheaton193
    Pheaton193
    from Reno, NV
    There is no room for a brake booster in my '53 and I am in a quest for the brake shoes that will reduce the pedal pressure as best as possible (for my wife, lol.) Have researched NOS Asbestos, Carbon Metallic & Kevlar as supported by Jeff. Did I miss any candidates?
    Any suggestions on the best way to go for less pedal pressure and fade?
    Tom
  2. cb186
    cb186
    I'm most concerned with you allowing the wife to drive the Ardun...... :eek:
    Rui likes this.
  3. Pheaton193
    Pheaton193
    from Reno, NV
    Because she let me put in an Ardun, I put in an AOD, Electric Power Steering and A/C for her! Now better brakes for her for the time(s) she may drive it!
  4. 55Brodie
    55Brodie
  5. okiedokie
    okiedokie
    from Ok
    mpbrakes.com has these. I am using a single in my 55. Here is a page from their site.
    The next logical question is, “How does it work?” There are two versions available: single and dual diaphragm units. The single diaphragm unit works well in a disc front and drum rear brake system. The dual diaphragm unit is designed for a four-wheel disc brake system. Vacuum is still needed to operate the system so a vacuum source, such as the engine, is plumbed into the booster using a conventional vacuum hose. From there, brake lines are plumbed from the master cylinder to the booster unit and then onto the remaining parts of the brake system. This gives the proper ***ist needed along with the comfortable feeling of a power brake booster.
    Single Diaphragm Remote Brake Booster – BS1010K
  6. Pheaton193
    Pheaton193
    from Reno, NV
    At this point, I am exploring non booster alternatives. I am using a dual outlet master cylinder with good results but now want to use the best brake lining. The booster may come later.
  7. Thriftmaster
    Thriftmaster
    from Canada
    Have not researched any of this but I have been hearing more about guys using electric brakes on there rods, wonder if you could convert them to the car?
  8. Pheaton193
    Pheaton193
    from Reno, NV
    Good thought, will look into especially since I installed electric power steering and I love it.
  9. Pheaton193
    Pheaton193
    from Reno, NV
    Anybody tried electric power brakes?
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    For drum brakes Advance Auto has Ceramic lined shoes for 1952-54 Fords they will decrease Brake fade and drum wear about 20-25 % over semi-metallic if you have not done so already do the self adjuster upgrade.
  11. Pheaton193
    Pheaton193
    from Reno, NV
    Thanks Jeff, do you have part numbers? Not listed on their site.
  12. Pheaton193
    Pheaton193
    from Reno, NV
    Advance says they don't have them
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. Pheaton193
    Pheaton193
    from Reno, NV
    Thanks .. Will check
  15. Pheaton193
    Pheaton193
    from Reno, NV
  16. JeffB2
    JeffB2
    from Phoenix,AZ
    The Porterfields would be a superior product to the Advance,we once had a musclecar brake company listed in the FAQ but they folded. Thanks for bringing these guys up, to get the Kevlar which is also used in HD Trucks some commercial clutch and brake rebuilders can reline your old shoes with that material.
  17. Pheaton193
    Pheaton193
    from Reno, NV
    Talked with Poterfield today and they are very high on their RD4 lining. Although much more expensive, it seems that they are superior as you say. "Send 'em back if you don't like them." More as I proceed.
  18. buymeamerc
    buymeamerc
    from s.c.,usa
  19. JeffB2
    JeffB2
    from Phoenix,AZ
    What year and model Merc ? I'll see if I can do a crossover for you.
  20. buymeamerc
    buymeamerc
    from s.c.,usa
  21. Skeetum
    Skeetum
    Here is what I am looking at putting in my '54.
    'By using 2 small manual race quality master cylinders this Wilwood pedal creates line pressures equal to or greater than ***isted systems. You also gain tremendous brake “feel” and the safety of never losing your brakes because of engine failure.'
    www.fabquest.com/wilwood-super-pedal-dual-master-brake-pedal-***embly.html
  22. JeffB2
    JeffB2
    from Phoenix,AZ
  23. Pheaton193
    Pheaton193
    from Reno, NV
    Looks great but will not work for me without major mods because of electric power steering mounting. So far, Dave's, Drop em n Stop em, master cylinder and disc brakes do not require as much pedal pressure as stock brakes. Seems if I want power brakes, ABS's electric master cylinder is my best solution. Need to hear more about it from others though before spending the $1k the ABS system costs. Then, I am hearing dissatisfaction with their customer service. That concerns me.
  24. buymeamerc
    buymeamerc
    from s.c.,usa
  25. buymeamerc
    buymeamerc
    from s.c.,usa
    so ... finally getting finish with the front suspension, now I have questions on the brake self adjust-
    I was taught by my old man that the "cable always goes on the rear shoe. If so, than the "star" wheel
    is installed backwards on one side so that the actuater(clicker) will reach the wheel, but the star wheel wont be accesseable thru the backing plate adjustment hole????????????????
  26. 56longroof
    56longroof
    You will have to drill a new adjustment hole. On my 56 I was able to get to it with a small screwdriver. Just barely though.
  27. Jimmy2car
    Jimmy2car
    from No. Cal
    Like Okiedokie, I have a single Hydrovac unit that I mounted under the car near the driveshaft front. Cannot see it at all, and easy to mount. Make a couple new lines and a vacuum source and you're all set.
    Mine is all drum brakes and self adjusting
