Technical Brakes
Discussion in 'Traditional Hot Rods' started by Oldfordsrule, Aug 15, 2017.
  1. Oldfordsrule
    Oldfordsrule
    New master cylinder, new power booster, everything bleed,some pedal when off , no pedal when running???
  2. Vacuum leaks to the booster?
  3. Atwater Mike
    Atwater Mike
    ...or IN the booster. Vacuum pulling diaphragm forward...
  4. X38
    X38
    Gee, welcome to the HAMB trouble shooting service, nice to meet you.
  5. greybeard360
    greybeard360
    Sounds like the pushrods from pedal to booster and booster to master cylinder may not be adjusted right.
    Sent from my Moto G Play using The H.A.M.B. mobile app
  6. 29moonshine
    29moonshine
    is the rod adjusted right when you put your foot on the pedal it should drop about 1 " when you crank the car
  7. Might as well join the HAMB team? Ya got pics of the car? What kind of car? Complete your profile?
  8. Is THAT what he wants?
    Ben
  9. Engine man
    Engine man
    from Wisconsin
    Just because parts are new doesn't mean they are good. I had a pickup truck that I had to put 3 new mastercylinders on before I got one that worked. On a power boosted system, the pedal should be rock hard with almost no free play with no vacuum on the booster. It must not be bleeding completely. I like to use low pressure air on the master cylinder to bleed brakes. Make certain that you don't have any places in the system that ca trap air like T fittings or couplers that are larger than the lines internally.
    chazehen and Atwater Mike like this.
  10. wbrw32
    wbrw32
    We sure would like to know more info First complete your profile,then come back and give the info on your vehicle....providing it falls into HAMB REQUIREMENTS...(nothing later than a 1965)
    patmanta likes this.
  11. 283john
    283john
    drum brake adjusters adjusted "out" far enough?
  12. bobss396
    bobss396
    Another 3 blind men examining an elephant post... be nice to have some real information.
    wbrw32 likes this.
  13. Atwater Mike
    Atwater Mike
    O.K., Bob... I wanna buy a vowel.
  14. bobss396
    bobss396
    A bowel... oh.... a VOWEL....
  15. torpedo jones
    torpedo jones
    Try bleeding brakes while car/truck is running, one person pushing on the pedal one person turning the bleeder valve. Don't use a speed bleeder.
