Technical brakes
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Feb 16, 2023.
  1. Huckster59
    Huckster59
    1940 ford deluxe. stock front suspension. and brakes up front. what’s a good conversion , disk. or get better drum system
  2. Huckster59
    Huckster59
  3. Mr48chev
    Your post will probably get deleted as the moderators don't like disk brakes. Simply because they don't fit the criteria of the board (pre 1964 style vehicles only and done in a pre 1964 style) . It's like having a blue nose Baptist mother in law, you don't drink in front of her nor talk about your drinking exploits, here we don't discuss certain parts even though many of us have them.
  4. da34guy
    da34guy
    Brakes are over rated LoL
    Rocket88NZ and '34 Ratrod like this.
  5. 31Apickup
    31Apickup
    In today’s traffic it’s understandable to want disc brakes, on a 40 you don’t see them like a fender less car so I don’t think it’s a big deal. There are lots of direct bolt on kits for 4” spindles and you can get which ever wheel bolt pattern you like even the Ford 5.5” bolt circle.
    gimpyshotrods likes this.
  6. Upgrade to a dual MC and rebuild your stock brakes. If you want to get fancy you can do a Buick drum upgrade with self energizing brakes up front off a later Ford.
  7. alchemy
    alchemy
  8. krylon32
    krylon32
    from Nebraska
    I've got Super Bell Power Stoppers on the front of my 40 coupe. Also I've sold dozens of the reproduction Lincoln self energizing brakes for the front of 40 Fords. Quite a few of the Lincoln conversions use the 1.75 width shoes and retain the stock 40 drums and hubs. Lots of options available.
    olscrounger likes this.
  9. jimpopper
    jimpopper
    Around here, Life stopped after 1965. We just have to accept that and live within those rules. Most of my experiences happened after that so I am an outsider here.
  10. el Scotto
    el Scotto
    from Tracy, CA
    I do agree, those 1939-1948 brakes can be finnicky sometimes.
    When I had it I upgraded my '48 Mercury to '53-'56 F100 brakes and they worked excellent with a stock rebuilt 3 bolt master. I've used that setup on hot rods before too with good success. You can literally change nothing else in the brake system other than the brake stuff from spindle outward so it makes the swap quite easy.
    A properly working drum system is completely fine most of the time. I commuted in traffic both ways in a '57 Chevy truck for years with four wheel drums and (gasp) a single pot master and I managed to not burst into flames and die. This included going over a hill with a 1000 foot climb in elevation twice every work day.
    That said, do disc brakes if you want. Certainly in higher performance heavier cars you'd want something better. My '70 Challenger has 11.75" discs up front and I wouldn't think to put drums back on it.
    Just be aware it's a whole system change that is more involved.
  11. If you want to use disc brakes, I recommend "ECI" disc brake conversions. The owner was the shop foreman for many years before buying the business. He knows his stuff.
  12. gene-koning
    gene-koning
    Since when did disc brakes become taboo? They were still considered a safety upgrade last year and was allowed, even discussed.
    Disc brakes, radial tires and factory appearing or originals upgraded to LED lights were allowed as safety upgrades for people that actually drove their cars in city traffic, when did that change?
  13. sunbeam
    sunbeam
    So no 350 chevys 5 speeds or overdrive automatics or even turbohydro 350 trans and only 396 BBC.?
    jimpopper and 2OLD2FAST like this.
  14. Pete1
    Pete1
    from Wa.
    Sevaral disc kits are available. I have Wilwoods on one of my cars. The stock Lockheed's can be modified to work very well for road racing by adding scoops and metallic lining. They will keep working even when red hot. They should last forever on the street.
  15. Where do you live, what kind of driving do you do? There's more than just 'period correctness' at work here.
    An older, lighter car can have more than adequate braking capacity with drums but as the cars get newer/heavier drums become less and less effective. If you live in the midwest flatlands and don't drive in urban areas, drums can be fine. But if playing dodge-'em in traffic with *****s in ABS-equipped late models, drums may not cut the mustard. Or if you live somewhere with big elevation changes, running out of brakes on a long downgrade isn't at all cool. Or do you occasionally drive it like ya stole it? Better brakes may be needed.
    Cost isn't much of a factor anymore, in fact discs may prove to be cheaper if you're looking to upgrade to larger brakes. And in spite of some claiming that 'drums work just as good', that's demonstratably not true or you'd still find drum brakes on new cars.
    Do what makes you feel safe(r).
  16. I’m building my drums.
    Adding a pre 65 dual MC just for kicks.
    If I don’t like the set up, I’ll go from there.
    But I’m not fixing something that isnt broke yet
  17. AngleDrive
    AngleDrive
    from Florida
    Boling Brothers, they will stop just fine and easy to maintain. Buy them from Krylon32.
    warbird1 likes this.
  18. hemihotrod66
    hemihotrod66
    I have driven mechanicals, and years when drums were all we had,,, Sorry traditionalists but I will keep the discs on my hotrod....
  19. Zax
    Zax
    Speaking from personal experience I do not recommend the front disk swap for a 1940 Ford. I've spent countless hours of labor and way too much money trying to get the disk conversion that was on my '40 when I got it perform as it should. I plan to rip it out and go the F100 front drum route instead.
    https://www.jalopyjournal.com/forum/threads/f100-brakes.226861/
    Nailhead Jason and RAK like this.
  20. jimpopper
    jimpopper
    Correct! Most hide them under period correct dressings. No plasma cutters, welding was usually more primitive and no clear coat urethane paint..
  21. Kerrynzl
    Kerrynzl
    @Huckster59
    @Tman has given the best advice here.
    This forum is full of threads where people "get out of there depth" disc brake conversions.
    I've given up on helping these people because all the want to do is justify using the junk they have already purchased [when they should "bin it"]
    A dual braking system is all you need, and if you are a spirited driver [a late apex, diamond pattern driver] then maybe upgrade the friction materials on a stock system.
    https://porterfield-brakes.com/manufacturer/brake-shoes/
    These ain't cheap, but at $200 for 4 shoes [$400 a whole car] it will be a lot cheaper and better than some universal ****rel disc brake conversion kits.
    And note: Brakes don't stop the car........The tyres do [brakes only remove kinetic energy]
    So the only other mod I would consider is some way of cooling the drums.
    Tman likes this.
  22. Huckster59
    Huckster59
    thanks. i think i’ll just try to dial these in.
    chevyfordman likes this.
  23. gimpyshotrods
    gimpyshotrods
    Brakes?
    Why would anyone want to stop doing what they love?
    seb fontana and V8 Bob like this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    this is not true, we do not have anything against disk brakes here.
  25. Huckster59
    Huckster59
    woo i feel better 327.4 speed and and no clear coat im safe
    302GMC likes this.
  26. tommyd
    tommyd
    from South Indy
    Scarebird is an Alliance Vendor and sells lots of conversions.
  27. Huckster59
    Huckster59
    im thinkin it just needs the correct adj, after rear a bunch of post i most likely am not adj correctly ,just got over covid and heading to garage today
    treb11 likes this.
  28. neilswheels
    neilswheels
    from England
    On my 40, I'm fitting f250 front backing plates and internals with buick drums on the front, and early f100 on the back with dual circuit m/c just for safety, I was going to go stock 40, but these upgrades are pretty simple, and relatively cheap, compared to Lincoln stuff.
  29. manyolcars
    manyolcars
    except Tman said, "self energizing drums". Drums are not self energizing.
    Brakes are enough of a headache that we need a 'Brakes' subforum
  30. manyolcars
    manyolcars
    scarebirds parts do not fit my 1950 Crestliner without grinding on the steering arms and I dont like that idea. Stay away from scarebird
    Atwater Mike likes this.
