Technical brakes
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Feb 16, 2023.
  1. Pardon the slip. You and most others knew what I meant
    Tow Truck Tom and BJR like this.
  2. Thank you, Sir..
    Ben
  3. Huckster59
    Huckster59
    i live in rural area so alot if state roads.
  4. Kerrynzl
    Kerrynzl
    We actually need to teach people to not "reinvent the wheel"
    Vendors like "Skeerbird" are only component suppliers, that are actually relying on the competence [or incompetence] of their customers
    As soon as sombody adds a front disc brake conversion they upset the whole brake balance of the vehicle. There is a ****load of math and variable factors involved [more than an online calculator can provide]
    My advice is "leave it alone" but if you insist on added upgraded components, then select a whole donor vehicle of similar weight/wheelbase and cannibalize all the matching components.
    The factory's have some pretty good enginneers that have done the "hard yards" in designing brakes for multiple conditions [but people think that "romantic" components are better]
    I have yet seen a hotrod with DIY upgraded brakes that can stop as good as a 35-40 year old Japanese Hatchback.
    Don't worry ! I''ve got your back here.
    From the magical world of "wikipedia" [below]
    Drum brakes have a natural "self-applying" characteristic, better known as "self-energizing." The rotation of the drum can drag either one or both of the shoes into the friction surface, causing the brakes to bite harder, which increases the force holding them together. This increases the stopping power without any additional effort being expended by the driver, but it does make it harder for the driver to modulate the brake's sensitivity.
    X-cpe and Tman like this.
  5. 57 Fargo
    57 Fargo
    All of this. Thanks Kerry!
  6. jimmy six
    jimmy six
    Adequate brakes are needed to safely load and unload your vehicle from a trailer. Stopping will done by the parachute. :rolleyes:
    Illustrious Hector and Tman like this.
  7. choptop4
    choptop4
    My disk brakes where made in the 40s.
    winr, warbird1 and Tman like this.
  8. Huckster59
    Huckster59
    i tried adj by the motor book today. thought i had it good pedal. first hit pulled right. second time got. better. and better. now this. ar has been in garage over 20 years not moved. i replaced wheel cyls mast cyl ,had a early 60s chevy rear axle i loose the pedal i’m going to adj rear in the morning i did notice one of the br*** adj on bottom was pretty worn. i’ll keep diggin at it. thanks all. i really don’t want to put disc on it. when ya hit the brakes pretty hard ya feel a good roller feel , like a bearing. all bearings were cleaned and checked and greased.
  9. Huckster59
    Huckster59
    another question. i notice on replacement brakes the lining are all full. , mine has a long lining and a short. long lining on back of front plate and short on front of plate. correct?
  10. gimpyshotrods
    gimpyshotrods
    In this case, no. Those are the guidelines for Bendix brakes.
    In the case of Lockheed brakes, which the early Ford ones are, it is the reverse. Long in the front, short in the rear of each backing plate.
  11. Huckster59
    Huckster59
    that’s they way i have them. well i got a pretty good pedal now. adj the rears and made a hell of a difference. has a little pull to the right. i’ll jack back up and check adj again
  12. Huckster59
    Huckster59
    shoot i guess mine are wrong then. i’ll have to double check. i put back on the way they came off.
  13. 19Fordy
    19Fordy
    1940 Fords came with Lockheed brakes.
    1st photo is stock 1940 Ford left rear brake. Driver side
    Second photo is stock 1940 Ford left front. P***. side
    Longer shoes go on the front.
    Larger dia. of wheel cyl. faces toward longer shoe.
  14. el Scotto
    el Scotto
    from Tracy, CA
    For real? I just learned something new today! I've always thought it was always the Bendix way. What's the reason for the Lockheeds being backwards?
    I may have to go fix something else on my car now. :D
  15. Kerrynzl
    Kerrynzl
    The larger bore [staggered wheel cylinder] and larger shoe go to the front
    winr and warbird1 like this.
  16. gimpyshotrods
    gimpyshotrods
    A couple of things should be noted on a Ford Lockheed wheel cylinder, and the backing plate.
    There are only three bolts. This is so you know if you put it on the wrong side.
    The other thing to note, is that this is a dual-bore wheel cylinder. One is larger than the other.
    Lead shoe, trailing shoe. Each requires a different volume of fluid to move the shoe against the drum, so one gets there first.
    Small-bore, small-piston, less fluid volume to move it the same distance, shoe arrives at the drum first.
    Unlike Bendix brakes, the other end of each shoe is constrained by bolt, so the shoes don't interact.
    With Bendix brakes, the lead shoe grabs, rotation causes it to push on the adjuster, which pushes on the trailing shoe, which is also being pushed at the other end, by the wheel cylinder.
    Hence "self-energizing".
  17. Huckster59
    Huckster59
    well i’ll have to pull drum off see way mine is. thanks for pics. i’m pretty sure they are backwards.
  18. Atwater Mike
    Atwater Mike
    Lockheed brakes have shoes 'anchored' at bottom. The shoe that contacts the anchor pin has the longest lining.
    In a Bendix brake, there's NO anchor pin at the bottom; It's now at the top. Both shoes expand and the one that arrives at the anchor pin (in this case, the rear shoe) will have the long lining, as it's the 'working shoe'. the front shoe is the 'servo' shoe, so shorter lining.
    It's all about the anchor, and the direction of the drum!
    gimpyshotrods likes this.
  19. gimpyshotrods
    gimpyshotrods
    With Bendix brakes, the more pressure you put in the system, the more the lead shoe pushes both against the drum, AND against the trailing shoe!
    It amplifies the work you put in.
    With Lockheed brakes, the lower end of both shoes are always in contact with the anchor. The shoes do not interact.
    The one ***ociated with the small bore and piston gets the short lining.
  20. 19Fordy
    19Fordy
    The Bendix Brake system is self energizing whereby the brake shoes are pulled tight against the drum
    when the shoes contact the drum as the drum rotates. That's why the longer shoe is positioned facing the back of the drum. This provides improved stopping power. Lockheed brakes do not have this feature and were eventually replaced by Bendix style brakes.
    This site tells how Bendix Brakes works better than Lockheed.
    Drum Brake System Basics - Night School (motortrend.com)
  21. sunbeam
    sunbeam
    what brand they don't look like Lambert?
  22. okiedokie
    okiedokie
    from Ok
    Front discs on my40 make it safe to drive in todays traffic.
  23. Huckster59
    Huckster59
    well pulled drum off. mine are correct i think it’s just fine tuning adj on front now, the back brake adj fixed the low pedal. i think will do u til i get the disc. found a piece in my stash for master cyl.
  24. Huckster59
    Huckster59
    E74F8B46-9102-4D71-84E3-B7CDC9DF5537.jpeg this is the part
  25. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I have a nice 36 five window/hot rod flathead(60 years flathead experience) 5 spd manual, 66 Ford pickup nine inch. I run the 90 finned Buick(little later years than 45 fin) and am very satisfied with the braking performance—-no power brakes,no proportioning valve, dual non power m/c under floor. These drum brakes work quite well for my use. Flatheads Forever!! E9643B9C-1DAC-4A39-83B5-FEFED98FE10E.jpeg 455E6621-CE69-42FB-92D8-0930606FABC6.jpeg 868EC33F-EB41-469F-B8B9-8977D219A0B3.jpeg 5AD20B8F-CBD7-42B2-BB03-764C32FE8C19.jpeg DAE848D2-7BA6-44CC-9811-6053D6F19BAF.jpeg
    winr likes this.
  26. seb fontana
    seb fontana
    from ct
    Kinmont I think.
  27. 1971BB427
    1971BB427
    from Oregon
    If we stuck strictly to 1965 cutoff, not sure even a dual reservoir master would be allowed for many builds.
    coast40 likes this.
  28. V8 Bob
    V8 Bob
    There are two basic drum brake designs, servo and non-servo. Bendix is servo, Lockheed is non-servo.
    A servo design places most of the braking force on the upper rear secondary shoe, the reason the rear linings are longer and usually of a different and sometimes thicker material than the shorter front primary linings.
    Non-servo, in particular the Lockheed fixed anchor design, places most the the braking force on the lower front primary shoe, and is the reason the front linings are longer, along with larger wheel cylinders, than the shorter rear secondary linings and smaller wheel cylinders.
  29. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Only if it came from an AMC or a Cadillac.
  30. Huckster59
    Huckster59
    took a drive in car today. first longer drive 15 miles shake down run. ran great ,stop not so good. ya no when rotors get warped? that’s what it feels like while stopping. mmm
