Brass Cleaner
Discussion in 'The Hokey Ass Message Board' started by strombergs97, Feb 10, 2011.
  1. strombergs97
    strombergs97
    OK, what can I use to clean br***, is there a liquid I can soak br*** in and they come out clean..???????
    Duane..
  2. 1952henry
    1952henry
    Br*** what? I run dirty fittings, screws, etc. over a mild wire brush on the grinder. Slicks them up nicely. Press too hard, and well, you know.:mad:
    Then I hit them with Collinite boat wax if they will be obvious.
  3. Mr48chev
    I think regular Carb cleaner will clean it up and then if you want to shine it up, Good old Br***o The old time GI's nemisis and a bit of time will put a shine on it.
  4. scarletfever
    scarletfever
    from texas
    Simichrome polish (find at a good hardware store) for large areas that show. it leaves a long lasting shield against tarnish.
    not good for bolts or small tedious parts
  5. Dman
    Dman
    I heard this from a guy in the Navy and he may have been pulling my let but he said that they would soak br*** in kool-aid with no sugar to clean br*** on the ship he was on. I have never tried it but that is what I was told. Try it and let me know how it works. It sounds crazy to me but maybe it works.
  6. DrJ
    DrJ
    I saw a show on TV yesterday where they scrubbed the tarnish off a copper pan with a half a lemon on a pile of table salt.
    Bronze is mostly copper.
    They also used lemon and baking soda on stuff to clean too.
    I know some people who clean the bluing off chrome headders with lemon juice.. wash it off befor fireing it up though!
  7. 26 roadster
    26 roadster
    preventative maintenance on br*** in the Navy is soaking overnight in red bug juice. it has no flavor it's just red. LOL It really works on br*** floor drains from the galley(kitchen for you land lubbers)
  8. TerrytheK
    TerrytheK
    Don't know about soaking br*** parts - just about anything I've ever tried on br*** involves elbow grease. For cleaning polished br***, I've had good luck with this stuff: http://www.englishcustompolishing.com/usca/museum.html
  9. nofin
    nofin
    from australia
    Depends what kind of "dirty" it is. If it's just tarnished then almost any cleaner will work.
    (FWIW a solution of water with of 100g/l (approx 13.5oz/US Gal) of pot***ium cyanide and 50g/l (6.75oz/US Gal) of caustic soda will clean it instantly!!!DON'T TRY THIS AT HOME!!)
    If it's corroded then 20:1 water to sulphuric acid is good for cleaning all the deposits off. Won't happen instantly.
    Doesn't matter what cleaner you soak it in, it will not polish it. You will still need to buff the surface to get it shiny. All soak cleaners do is make it easier to buff after.
  10. x-shift
    x-shift
    Taco Bell hot sauce.
  11. hotrod40coupe
    hotrod40coupe
    Pure lemon juice and salt does a great job. Using baking soda with any of the solutions will only neutralize the acid, which is the agent that cleans the br***.
  12. ghille45
    ghille45
    Br***o is what we used in the marine corp.
  13. unkledaddy
    unkledaddy
    50:50 muriatic acid and water, then Br***o or the like with a lot of elbow grease.
  14. Gator
    Gator
    from Statham Ga
    Br***o and Nev-r-dull is what we used when I was in the Navy. Eagle polishes bought the Nevrdull name, you can find it at most auto parts stores. It's basically cotton wadding soaked in polish - you tear off a hunk, use it till it's all black and toss it.
  15. CutawayAl
    CutawayAl
    from MI
    Br*** is an alloy of zinc and copper. Cleaning br*** with acid burns away the zinc, leaving the surface a copper color. The same is true of paint stripper. The only way to fix that is to expose unaffected underlying metal by polishing and buffing away a layer of metal from the entire surface of the part.
    Ammonia removes br*** corrosion. Commercial br*** cleaners often contain ammonia. It won't remove paint or what remains of any old protective clear. For that, lacquer thinner works well on most coatings other than powder coat and catalyzed paints. You didn't say what the parts are, or what you want them to look like when they are done. Depending on the condition of the parts, after cleaning you may want to hand polish then with a metal cleaner/polish, or with a powered buff and compound.
  16. GZ
    GZ
    from Detroit
    There is a great product called Venol. Works especially well to maintain br*** and keeps the shine for longer than any other produce I've tried. I am not at home so don't have any info. I know Restoration Supply Company in California sells this but I am sure it is available elsewhere. From memory, I think it might be made in Germany????
  17. cruzr
    cruzr
    Br***o..............been around forever...........works!
  18. CutawayAl
    CutawayAl
    from MI
    Per my post about ammonia, Br***o contains ammonia, and a light abrasive to polish the part.
  19. rond
    rond
    Ammonia should never be used on thin br*** sheet parts. Remember the recalls on natural gas pipes made from br***? The ammonia leads to stress cracking.
  20. CutawayAl
    CutawayAl
    from MI
    Yes, the alloy is degraded by contact with ammonia. The degradation caused by a brief cleaning is real, but minuscule. The amount of metal removed by polishing and buffing takes away more strength than a little exposure to ammonia. On the other hand, continuous exposure to ammonia will eventually ruin the br*** parts. Ammonia has the same effect on plain copper, and on bronze and other copper alloys. How resistant the metal is to attack depends a lot on the exact alloy. Right or wrong, professionals use ammonia to clean instrument and clock and instrument parts, with no apparent damage.
  21. tommy
    tommy
    Tarn-x will remove the oxidation but it won't shine without some elbow grease and a polish.
  22. Boozer
    Boozer
    Do a google search for products used to clean br*** bullet cartridges. I'm not sure how well they shine it up though...
  23. carbking
    carbking
    If you are talking about br*** floats do NOT use Br***o, or any other abrasive. The heat from rubbing the br*** will cause the br*** to become brittle and crack. Cracks are not desirable on br*** floats.
    Jon.
  24. Tripple G
    Tripple G
    As far as cleaning br***, I use to work on steam locomotives, which had many br*** appertances. I've used them all, and for my money, the best polish/cleaners out there were Wenol metal polish and Mother's polish. Used these on many a locomotive bell and steam engine gauges, with much success.
  25. Cymro
    Cymro
    Cola works soak overnight,
    Phosphoric acid weak solution soak overnight,
    vinegar,again soak overnight,
    Two slightly off the wall remedies are tomatp ketchup and HP Sauce (Brown sauce) the acidic vinegar and mol***es in the HP sauce do a realy good job, smear leave for a couple of hours and rinse off with Fairy Liquid (Dish washing detergent) then polish.
