Technical Brass Gas Tanks — Examples & Help Needed!
Discussion in 'The Hokey Ass Message Board' started by doctorZ, Mar 4, 2024.
  1. doctorZ
    doctorZ
    I am looking to form a br*** gas tank for my cycle-car since it fits the era and will be exposed. I have a some experience with brazing steel using bronze and sweating copper (basic plumbing) but no real experience with brazing br*** so I have the following questions:
    • People who have made br*** gas tanks, what thickness did you use?
    • Are you using straight br*** or a copper alloy?
    • Are you doing lapped or ****ed seams?
    • What filler are you using?
    • Did you coat the tank with anything to prevent oxidization?
    • Any videos or tutorials you can recommend?
    Finally, if you have any pictures of br*** tanks for inspiration I would love to see them!
    AccurateMike likes this.
  2. FrozenMerc
    FrozenMerc
    Search Br*** Fuel Tank Kits for Hit and Miss engines. Lots of kits out there, although probably too small for your application, but they should give you ideas on material, sizing, etc.
  3. GZ
    GZ
    from Detroit
    Ziggster likes this.
  4. doctorZ
    doctorZ
    Yes! They do absolutely incredible work but I need a very specific shape to fit the fairing so I'll need to make it myself
  5. 1932tub
    1932tub
    I would not recomend br*** for a car fuel tank, joints would have to be lapped riveted and soldered or seamed and soldered. Could be gas welded but the warpage would be horendous. I have tig welded heavy gauge br*** with parent metal filler and reverse polarity but would not bother to do this with light gauge.
  6. Ziggster
    Ziggster
    Would be nice to see what you come up with as I was looking into making a copper gas tank, but gave up on the idea.
  7. 5window
    5window
  8. goldmountain
    goldmountain
    You don't braze br*** parts; you solder them.
  9. Ziggster
    Ziggster
    We brazed all kinds of br*** parts to copper in our mobile HVAC units. All the copper fittings were brazed on the heat exchanger coils we made in house.
    loudbang and 2OLD2FAST like this.
  10. Cgrgrspt10
    Cgrgrspt10
    Can you build a steel or aluminum welded rank and clad it with br***? Foux rivets?
    bobss396 likes this.
  11. bobss396
    bobss396
    I raced with a guy in the new Novice division at Islip. Most of us used VW tanks strapped to the trunk floor and they were approved.
    This one guy had a new car for the season, in the trunk was a 24" cube of a gas tank. I'm not doing the math, but the builder said it was FULL on opening night. A few races later we found out that it was made of .050" COPPER sheet.... Tech totally missed the fact that it was not steel.
  12. Budget36
    Budget36
    Just a question, do you anneal br*** sheets to be able to form them, like copper?
    I watched the show Jesse James had when building MC’s and he made a copper tank as I recall, annealed it with his OA and it softens up to form.
    Made really cool chopper tank.
  13. AccurateMike
    AccurateMike
    I have been thinking of the same thing. I once worked as a "Metal Artist Craftsman" at a cool place called Heritage Metal Works. They had a foundry and metal art shop with tons of neat stuff going on. I had never done it and just went up with a trunk full parts of I had made. (he liked this I think http://www.accuratepower.com/Machine/fabrication.html )They hired me and I just started doing it. They gas brazed all of their br*** and bronze together. He called it "soldering". I had soldered a bunch before and what we were doing was way hotter and a little harder to do. I looked up the wire and flux and it was for brazing carbides on to steel shanks. They used it because you could polish the braze line away, it blended real well with the br*** and bronze, and was strong as ****. I also had to forge some shapes from chunks of br***. Just like a blacksmith with iron except you would anneal, cool, hammer, re-anneal and so on. You only get a few anneals before the br*** would crack. Hammering work hardens so you have to move the metal right the first time. It was more of a ***** than blacksmithing.
    My thinking on a tank is that the trick would be in the seams. You would need some kind of lap or rolled over joint that you could flow the braze into. I would pack the joints with flux before I crimped them. Wouldn't be as hard to make something tubular or square, tougher to make a shape. Breaking the edges to make the joints would be harder on a curve. They did it though, tops of lanterns and such. Good luck ! I'll be watching. Mike
    A "how to" link https://www.oldmarineengine.com/discus/messages/3433/253935.html
    Some HMW stuff I did
    37663456_404890309917834_1498884027992506368_n.jpg 37726943_404890269917838_496779166113333248_n.jpg
    5window, RMR&C, rod1 and 3 others like this.
  14. 57Fury440
    57Fury440
    I miss Islip Speedway. My older brother took me there when I was a kid. Later when I got my own car, I raced on the eighth of a mile track. Other than the look of br*** why would someone want a br*** tank?
  15. doctorZ
    doctorZ
    Why would it have to be riveted and then soldered? I feel like I have seen quite a few tanks that aren't riveted. Can you tell me a bit more?
  16. doctorZ
    doctorZ
    Technically I can but emotionally I can't.
  17. Beanscoot
    Beanscoot
    A friend made one of them live steam model engines, he used silver solder for joining the br*** and copper plates of the firebox, which might be overkill for a fuel tank but it is extremely strong.
    If you use soft solder, I'd choose the lead free solder since according to one of the copper fitting makers, it's about twice as strong as lead / tin solder.
  18. Beanscoot
    Beanscoot
    Boy that Br***works place isn't cheap. Over a million bucks for a polished Ford tank!
    SS327 and 5window like this.
  19. 2Blue2
    2Blue2
    Only got sell one!
    SS327 likes this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    You need to get out more ...
  21. bobss396
    bobss396
    We silver soldered a lot of br*** at one machine shop I worked at, we did RF waveguide work. The joints were quite strong, we could easily machine the br*** or copper flanges after they were attached.
  22. 5window
    5window
    If it's only for appearances, get a steel tank and copper plate it.
