Hot Rods Brass Injector fitting Man A Fre Manifold
Discussion in 'The Hokey Ass Message Board' started by bustingear, Oct 11, 2015.
  1. bustingear
    bustingear
    Working on my Man A Fre and have a need for one or two of these injector fittings.
    Any one have some lying around?
    One side of the elbow is also threaded inside.
    Any help woud be appreciated.
    Thanks
  2. elgringo71
    elgringo71
    Try Mc master Carr, they should have those.
  3. bustingear
    bustingear
  4. pdq67
    pdq67
    I didn't think Man-A-Fre's used injection parts? More like (4) 2G's or 2GC' carbs?
    Where do the parts go on the manifold.
    pdq67
  5. bustingear
    bustingear
    Below each carb one on each side
  6. stimpy
    stimpy
    should be able to take a standard 90 and tap it with a hand tap
  7. PackardV8
    PackardV8
    Yes, most Man-a-Fre setups used Rochester 2GCs, but there were a few equipped with four Scott injectors, if memory serves, but it's been a while. The Scott was "the poor man's injector," using Stromberg 97 bases, throttle bodies, jets and other parts.
    jack vines
  8. mgtstumpy
    mgtstumpy
    Is this the Man-A-Fre with Scott afterburner system. From what I recall the 'afterburner' system was a constant flow injector system triggered by a solenoid at WOT.
    This NOS unit was sold on HAMB in 2014
