brass nipple in brake lines?
Discussion in 'The Hokey Ass Message Board' started by bsduece, Jun 21, 2012.
  1. bsduece
    bsduece
    I've got my line running to the rear, 3/16 line going from master cylinder to RPV to adjustable proportioning valve. Instead of running a small 3/16 brake line from the rpv to the valve I just connected the two with a br*** ****** about an inch long. Is this acceptable or does anyone with brake/hydraulic knowledge say no to this?
    Thanks
  2. Ole don
    Ole don
    Br*** is OK only for fittings. You are fine.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  4. Is that pipe thread and Teflon tape ?
  5. unkledaddy
    unkledaddy
  6. dreracecar
    dreracecar
    from so-cal
    The only Issue I have is going through different ID's within the system is a good place for air bubbles to get caught. Would have been better to use a short 1/8 npt coupler with a 3/16 ID to connect the rpv to the bias and run a longer line to the master keeping everything 3/16 ID throughout.
  7. nickleone
    nickleone
    Are the tubes double flared? If not you might get a leak.
    Nick
  8. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    How do you double flair a br*** ******? :rolleyes:
  9. jcs64
    jcs64
    All these valves come w/ pipe threads (1/8 npt) and are not flared fittings
    jeff
  10. Where can we get a coupler like that?
  11. dreracecar
    dreracecar
    from so-cal
    Its a standard fitting one can get from the many places that sell braided hose fittings or industrial places like Grainger or Mcmaster-Carr. I've got a box of about 100 of them --come over and I will give you one
  12. MAD MIKE
    MAD MIKE
    from 94577
    It's hard to see what kind of coupling that is.
    How is it sealing to the other fittings?
    You would want something like this between two components.
    If its just a simple piece of br*** ****** like this...
    It will leak, and possibly burst.
    There is a reason why brake line br*** fittings have such thick walls. Brakes regularly operate in the 600-900psi range. In a panic stop you can easily double that.
  13. thunderbirdesq
    thunderbirdesq
    You've got it right, those fittings are designed for pipe tapered threads. I would support the other end of the RPV with a line clamp. Also ditch the teflon tape, that **** has no place in a brake system. The br*** is a soft enough compound to "mash" and seal well when tightened properly.
