brass nuts Anybody got them?
Discussion in 'The Hokey Ass Message Board' started by 1ton, May 19, 2012.
  1. 1ton
    1ton
    I'm not sure what you expected but i'm talking about using them on plain steel exhaust studs. You know...to tighten up the donut to the pipe.
  2. squirrel
    dorman should have them. I use stover lock nuts and antisieze compound
  3. i got some at adcance auto
  4. 1ton
    1ton
    I really don't need any right now but I was wondering how common they are.
  5. randall_pitz
    randall_pitz
    any auto parts should have them with studs
  6. willymakeit
    willymakeit
    The Ace Hdw. here carries them also. Might give them a try.
  7. G'day, Most common br*** nut used for exhaust is the 3/8-24. Dorman part number is 949-003. Should be able to get them at almost any Oreilly store.
    ms
  8. 72IH
    72IH
    Yea, I got a pair.
    They are usually in my wife's purse tho.
  9. sdluck
    sdluck
    Not in the freezer
  10. I had br*** monkey with them , then we had a cold snap and you know the rest.....
  11. Sumfuncomet
    Sumfuncomet
    If you are near a good marine hardware store it may be worthwhile to look thru the aisles, they have those and all kinds of other cool stuff
  12. 327-365hp
    327-365hp
    from Mass
    OK, what's the reason for br*** nuts or stover nuts? Are they easier to remove?
  13. vtwhead
    vtwhead
    Br*** will not sieze up to the stud as a steel nut does. Have used them on all my builds for years.
  14. 327-365hp
    327-365hp
    from Mass
    I did not know that. Thanks for the tip.
  15. bobss396
    bobss396
    Yup, br*** and steel do not react with each other. Years back, all exhaust studs were sold with br*** nuts only. I've used stainless steel nuts on them too. Of course always with never seize.
    Bob
  16. Deuces
    Deuces
  17. jimi'shemi291
    jimi'shemi291
    X2. Struggling with old rusty factory nuts made me a believer in br*** nuts. But Jim & others are right about anti-seize compound. You know you may take it apart some time in the future. So why not make life easier by planning for that, right?
  18. bobss396
    bobss396
    Never seize is still evident when I dis***emble exhaust parts that have it applied... turns to dust from the heat, but it still works!
    Bob
  19. Harms Way
    Harms Way
    This lil' fella' had a couple until last winter
  20. fleet-master
    fleet-master
    Mike Boyd probably has 'em....no wait...balls of hardened steel are needed to drive a fuel altered...:D
  21. belyea_david
    belyea_david
    from Regina, SK
    International used to use copper plated bolts for their exhaust manifolds. It was easy to tell which bolts had been replaced bt the PO, they all broke off. The copper plated ones were just like you had usef high temp antiseize. It was friggin' amazing.
