Technical Brass nuts
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jun 22, 2025.
  1. johnfin
    johnfin
    from Florida
    I head that you should use br*** nuts on exhaust bolts but my bolts are stainless. Guy at the hardware store said never mix stainless and br***. Is that bs?
  2. 38Chevy454
    38Chevy454
    Shouldn't be an issue. What you don't mix is a stainless with stainless- it can gall and basically lock up the threads. But with stainless studs, you can use steel nuts.
  3. 05snopro440
    05snopro440
    Generally, stainless and br*** when in direct contact can result in corrosion.
    In actuality, it depends on the grade of stainless as they can have significantly varied electrical potential.
    If your bolts are a 300 stainless (like 304), you'll be much less likely to see significant corrosion than if they are a 400 stainless (like 410).
    ekimneirbo and chryslerfan55 like this.
  4. 05snopro440
    05snopro440
    Galling is combated with anti-seize, also using steel with stainless as you mentioned can help.
  5. RodStRace
    RodStRace
    jimmy six likes this.
  6. Bandit Billy
    Bandit Billy
    I use a lot of stainless hardware (exhaust system included), most of it polished and expensive. I have had to cut a lot of bolts off that I installed just for mock up during construction! Anti Seize is your friend, use it liberally any time you grab stainless hardware. Never used br*** nuts other than on a coil.
  7. 57 Fargo
    57 Fargo
    There’s a ton of mopars that had br*** exhaust nuts from the factory.
    bobss396 likes this.
  8. nochop
    nochop
    from norcal
    I only use stainless on non structural items such as trim or cosmetic items
    Jagmech likes this.
  9. gimpyshotrods
    gimpyshotrods
    Br*** is more anodic than stainless..
    When you put br*** on stainless, it can cause galvanic corrosion, and corrode the br***.
    Just Gary and 26 T Ford RPU like this.
  10. 05snopro440
    05snopro440
    Yep, people are always amazed how fast stainless can gall. It happens very quickly.
    Weedburner 40 and Bandit Billy like this.
  11. Three conditions are needed for galvanic corrosion: dissimilar metals, electrical contact (meaning direct or close contact so electrons can flow), and an electrolyte (salt water or moist air, usually).
    Today, I finally fixed the m***ive exhaust leaks on my cl***ic foreign daily driver and used br*** nuts (on steel studs).
    38Chevy454 and gimpyshotrods like this.
  12. The br*** nuts you need are "br*** manifold nuts", they are longer than the usual nut.
    vtx1800 and Rickybop like this.
  13. gimpyshotrods
    gimpyshotrods
    The OP is just outside of LAKEland.
  14. bobss396
    bobss396
    I used to buy regular steel exhaust studs that came with br*** nuts. They always came off.
    Now I use all stainless with never seize.
  15. earlymopar
    earlymopar
    Most of the galling that takes place with stainless fasteners is because the wrong grade of stainless was used....
  16. stuart in mn
    stuart in mn
    The thing is, the grade of the stainless fasteners you find at the local hardware store is usually a mystery.
  17. earlymopar
    earlymopar
  18. Bearing Burner
    Bearing Burner
    from W. MA
    I know that Ford in the late '40's used br*** nots on exhaust manifolds
  19. Corn Fed
    Corn Fed
    I always use the long br*** nuts on exhaust manifolds, with steel studs.
    Is anti-seize even able to withstand the high temps of an exhaust manifold in the long term?
    Bugguts and Moriarity like this.
  20. stuart in mn
    stuart in mn
    Regular old Permatex antisieze is rated for use up to 1600 degrees F, you can also get high temp antisieze that's good to 2500 degrees or more.
    gimpyshotrods likes this.
  21. The OP is in the Florida panhandle. I don't know if the high humidity alone would be a catalyst for galvanic corrosion, but I'm fairly certain that the salt-air environment is. It seems that using br*** nuts in those conditions would go against the purpose- preventing them from seizing on the studs. Maybe he can run an experiment.
  22. woodiewagon46
    woodiewagon46
    from New York
    Model A Fords came from the factory with br*** nut's on the manifold to muffler clamp.
  23. DDDenny
    And as you know SS is not impervious to rusting, some are much better at resisting rust than others, I can't remember the grade numbers, many are in Chinese now!
  24. 5window
    5window
    It is well established that people who drive MOPARS need br*** nuts.
    alanp561, RodStRace and Budget36 like this.
  25. 19Fordy
    19Fordy
    I remember I once used some bronze nuts on my flatty exhaust. No problems. Use anti-seize.
    alanp561 likes this.
  26. 304
    18-8 is regular hardware grade
    316 is marine grade
    Most are from all over. China, Taiwan, some USA. I get them from Mcmaster Carr or Bolt Depot.
  27. 38Chevy454
    38Chevy454
    I don't think galvanized corrosion is an issue. As stated by sgtlethargic, there really is not any electrolyte available. As example do any of the zinc plated bolts on your engine have galvanic problems? No they don't, even though zinc is anodic to the iron (steel). Same basic situation with br*** nuts, being anodic to the stainless steel. Unless your engine lives in water environment there just isn't an electrolyte. BTW, steel nuts are anodic to stainless as well; just not as much potential between them as compared to br***.
  28. gimpyshotrods
    gimpyshotrods
    Chemistry is governed by the Laws of Physics, and wastes no time considering the opinions of mankind.
    rocket hot rod and klleetrucking like this.
  29. gimpyshotrods
    gimpyshotrods
    rocket hot rod and 5window like this.
  30. earlymopar
    earlymopar
    Yep. the ferritic grades have more iron and less nickel and chromium and do rust as well as the martensitic grades in the 400 series that have more carbon and are heat treatable.
