Breakdown kits-What do you like to carry in your ride?
Discussion in 'The Hokey Ass Message Board' started by batt69nova, Sep 16, 2010.
  1. batt69nova
    batt69nova
    from OR
    Was just reading another thread and it got me going about how this last Sunday, I had to replace the U joint on my OT pickup-on the side of the road.
    People I talked to were amazed that I keep a few spare parts in the truck, along with tools to replace them.
    Just wondering what you all consider essential items to keep in the trunk, under the seat, etc to help you deal with a side of the road fix? In the days of just calling AAA to get a tow home, does anyone even bother carrying tools anymore?
    For example:
    One thing I carried in my '69 Nova-A distributor wrench. Until I wised up and ditched the chrome dist hold down, that thing would come loose at the most inconvenient times.
  2. A cell phone and a small assortment of tools.HRP
  3. Merlin
    Merlin
    from Inman, SC
    I have a few tools and tire plug kit in one of these.
  4. Antny
    Antny
    from Noo Yawk
    I carry a "Harley Davidson tune up kit" :): pliers, BFH, a couple of screw drivers, duct tape, box of bandaids, bailing wire, flash light.
  5. squirrel
    Whatever I think I'll need to fix my friends' cars.....
  6. LAROKE
    LAROKE
    I've taken two cross-country, back road trips in my stock '55 Chevy pickup by myself. Both were just short of five thousand miles. I filled the pickup bed with tools, spare parts and supplies to ward off Murphy. It worked. No breakdowns! The only thing missing from the following list is the firearms, cell phone, AAA membership and navigator I carried. (The items in the following list designated as "0" is the current inventory. I had at least one of these items with me on the trips.)
    <TABLE dir=ltr border=0 cellSpacing=0 width=440><TBODY><TR><TD height=16 width="67%">
    TRAVEL TOOLS, PARTS AND SUPPLIES​
    </TD><TD height=16 width="33%">
    </TD></TR><TR><TD height=16 width="67%">
    Item​
    Quanity​
    </TD></TR><TR><TD height=22 width="67%">
    Engine Parts Box​
    </TD><TD height=22 width="33%">
    Push Rods​
    2​
    Throttle Spring​
    2​
    Starter Spring​
    2​
    Alternator​
    1​
    Vacuum line hose​
    2 paks 72"​
    Exhaust Pipe Gasket​
    1​
    Oil Flex Lines​
    1 pair​
    Oil​
    1 gal​
    Fan blade​
    1​
    Fan belt​
    2​
    Electrical Box​
    Distributor with points, condensor, rotor, cap​
    1​
    Distributor vaccum advance​
    1​
    Regulator​
    1​
    Starter​
    1​
    Starter switch (on starter)​
    1​
    Spark plugs​
    6 r45​
    Headlamp​
    1​
    Cooling System / Electrical 2 Box​
    Water pump​
    1​
    Radiator hoses​
    1 ea top &bot rad​
    Radiator hose clamps​
    1 each​
    Heater hoses​
    20' x 5/8"​
    Heater connector and clamps​
    1' conn, 2 clamps 5/8"​
    Assorted Clamps​
    Emer Clamp Kit​
    Thermostat and gasket​
    1 ea​
    Coil​
    2​
    Ballast resistor​
    2​
    Stop leak​
    0​
    Fuel System / Cooling 2 / Electrical 3 Box​
    Carburetor​
    1​
    Fuel Filter Replacements​
    2 elements, 4 gaskets​
    </TD></TR><TR><TD height=32 width="67%">
    Fuel Filter​
    </TD><TD height=32 width="33%">
    1 orig equip type, 0 napa #3001​
    Fuel line hose​
    1 pak 1/4" x 19"​
    Fuel pump​
    1​
    Turn signal flasher​
    1​
    Fuses​
    10a, 15a, 20a​
    Light bulbs​
    tail, parking, dash​
    Wire​
    14ga spool​
    Coolant​
    0​
    Chassis Box​
    </TD></TR><TR><TD height=34 width="67%">
    Wheel Bearings​
    </TD><TD height=34 width="33%">
    front and rear bearings and seals (1 ea)​
    Front and Rear Spring Shackles​
    1 each​
    Pilot Bearings​
    2​
    Throwout Bearing​
    1​
    Universal Joints​
    2​
    Speedo cable​
    1​
    Tie Rod Ends​
    1 ea​
    Pinion seal​
    1​
    Inner Tube​
    2​
    Brake System Box​
    Brake Fluid​
    12 fluid oz​
    Clutch Release Springs and rods​
    1 ea​
    Wheel Cylinders​
    1 ea (4)​
    Brake Shoes​
    1 set rear​
    Flex Lines and clips​
    1 ea (3)​
    Bleeder Screws​
    1​
    Fasteners​
    </TD></TR><TR><TD height=49 width="67%">
    Spare bolts, nuts, etc​
    </TD><TD height=49 width="33%">
    8 group boxes, body kit, engine kit​
    Gasket Sealant​
    0​
    Gaskets​
    0​
    Other Items​
    Maps​
    0​
    Coveralls​
    4 disposable​
    Gloves​
    1 box latex​
    Hand Wipes​
    1 can (100 wipes)​
    First Aid Kit​
    1​
    Accident reporting kit​
    1​
    Spare locking gas cap​
    1​
    Tie Downs​
    4 ratchet straps​
    Tools​
    Gas Siphon​
    1​
    Grease gun​
    mini gun​
    Funnel​
    multi-purpose​
    Duct Tape​
    1 roll​
    Wire Ties​
    1 pak​
    Fuel additive​
    (2) 12 oz cans​
    Loctite​
    .2 fluid oz​
    Penetrating Oil​
    12 oz​
    Wheel bearing grease​
    1 lb​
    JB Weld​
    1 pak​
    Shop Rags (use to pack other items)​
    pack of 18​
    Tools 2​
    Breaker Bar​
    18"​
    Screwdrivers​
    blade/phillips asortment​
    Gloves​
    Mechanix​
    Flare Nut Wrench​
    0​
    Flashlight​
    0​
    Under Seat Storage​
    </TD></TR><TR><TD height=65 width="67%">
    Clutch Kit - 10"​
    </TD><TD height=65 width="33%">
    disk, pressure plate,pilot bushing, throwout bearing, alignment tool​
    Jack​
    sissors jack​
    Umbrella​
    1​
    Jumper Cables​
    1 set​
    Spare Ignition Parts from last tune-up​
    plugs, points, condenser, rotor, cap​
    External Storage​
    Gas Can​
    5 gal gerry can​
    Potable Water​
    5 gal​
    Pickup Bed​
    Cardboard (creeper)​
    1​
    Parking Brake Cables​
    2​
    Oil​
    1 gal​
    Electrical Tools​
    1 kit​
    Homer Box​
    tuneup tools​
    Tote Box​
    Craftsman Mechanics Tool Kit​
    1​
    Portable Jumper/Air Compressor​
    1​
    Fire Extinguisher​
    1​
    SHTF Survival Kit and MREs​
    1​
    </TD></TR></TBODY></TABLE>
  7. Merlin
    Merlin
    from Inman, SC
    LoL I had to do that a time or two.
  8. Mike51Merc
    Mike51Merc
    Hey Laroke, if you got stuck you could just pull over and construct a new vehicle with all those parts.
  9. OshkoshRob
    OshkoshRob
    from Oshkosh
    among other tools....a 5 pound sledge hammer. Had to fix a friends bent wheel after a famous Chicago pot hole.
  10. batt69nova
    batt69nova
    from OR
    WOW. Not sure what else to say!
  11. chaos10meter
    chaos10meter
    from PA.
    Cell Phone and AAA card.
  12. colorado51
    colorado51
    - A good assortment of hand tools (50 piece Craftsman)
    - A few feet of fuel line
    - Hose clamps
    - Throttle springs
    - Fix-A-Flat (I have no spare)
    - Mechanics gloves
    - Jumper cables
    - A few 2x4's, about a foot long (to block the wheels)
    - A bottle jack
    - Assortment of fuses
    - Assortment of bulbs
    - Assortment of wire
    - Electrical tape
    - AAA card
  13. el shad
    el shad
    My Old Lady
    Cell Phone (so she can txt her friends and tell them I'm a dumb ass when we break down)
    Spare tire and floor jack
    Small tool bag w/ assorted hand tools
    water
    semi auto .380 with extra HiCap clip loaded (GOD BLESS ARIZONA!!!)
    Been trying to find a muzzle for the old lady to add to the kit but have been unsuccessful as of late.
  14. LAROKE
    LAROKE
    Or stay put and homestead :D
    I also carry a box of cigars. The first thing I do when I break down is smoke a cigar and let the panic bleed off. I find that if I think about the situation for about a hour before taking action, I can come up with a better solution. The cigar takes about a hour to smoke.
  15. scooterseats
    scooterseats
    from East Texas
    Good grief Laroke, it is a good thing that the weights and measure boys didn't stop you, I am sure that you were overweight!
  16. Antny
    Antny
    from Noo Yawk
    That ain't a truck you were driving, it was a garage on 4 wheels! :D
    I give you a ton of credit for traveling cross-country in an old pickup, alone. It takes some balls......and a ton of spares!
  17. LAROKE
    LAROKE
  18. I've been to the Nats in St. Paul,( 37 Chevy PU ) OK. City,( 41 Ford Coupe ) Columbus, ( 40 Chevy PU ) and never broke down. Three different cars. I carry a tire patch kit. a small tool box, and a cell phone with me now. I don't have much room in my roadster but I'm not making any long hauls anymore. I guess I've been lucky. I've had my Dads car club plaque on the back of all my cars, maybe he's looking down and keeping me running and safe. Thats my guess.
  19. Invicta
    Invicta
    Aside from the tool box I carry. I always bring a blanket and Gloves. In arizona even trying to change a flat can cause 3rd degree burns.
  20. Holy crap ... Laroke, I don't think I have that much stuff in my garage/shed/loft/basement combined ...
    I carry the "usual" tools plus a complete HEI, an alternator, fuel pump, tire repair plug kit, and some bulbs ... oh, and I bring the wife in case I need a push.
  21. Dave K
    Dave K
    A leatherman
    AAA card
  22. cell phone Cash & a CC & 2 Packs of Little Cigars
  23. thepolecat
    thepolecat
    1. S.F.C.C.
    zip ties are always useful
  24. Bigchuck
    Bigchuck
    from Austin, TX
    I carry a small toolbox with basic tools, a small floor jack, a couple of jackstands, oil, coolant, & a cell phone. I try to keep up on maintenance to make carrying a bunch of parts aroud unnecessary. Sounds like some of y'all might as well just tow another complete vehicle, just to be sure.:D
    I mean, how do you predict what is going to break unless your car is prone to breaking this or, that? I guess it more dependes on where you are going and whant you are driving.
    I think the biggest road side repair I have ever done was nothing more than a water pump. Not real fun, but do-able.
  25. Steve from PA
    Steve from PA
    A small tool bag with a rachet set, wrenches and pliers.\/ screwdrivers. I feel if you built it right it shouldn't let you down. I travel 5-6000 miles every year and no major issues 9for the past 30 years)
  26. Steves32
    Steves32
    from So Cal
    I don't expect to break down. I fix my shit before I leave, not on the side of the road.
    However- I do carry a AAA card, a cell phone, a small tool box that fits under the seat, padded straps for the flatbed tow guy (you know he won't have any), a rubber mallet for the knock-offs & that's about it.
    I drive somewhere almost every weekend. Routine maintenance will limit the amount of breakdowns.
    I've found out over the years that no matter what you pack in the car- that won't be the part that fails anyway.
  27. guitar man
    guitar man
    from Tulsa OK
    Each one of my vehicles has a small box with a BFH, a few screwdrivers, 6" crescent, cheapo 1/4" socket set, utility knife, pliers, needlenose, vice grips electrical tape, duct tape, wd40, a flashlight and shop rags.
    There are usually radiator hoses, belts, bulbs oil, tranny and brake fluid and a couple gallons of water or 50/50 on board too.
  28. -BFH
    -Pliers
    -bailing wire
    -screw drivers
    -duct tape
    -two adjustable spanners
    -flash light
    -couple hand guns
    -copy Jack kerouacs "On the Road"
    And I got this sweet little vintage metal tool box in olive drab with a leather handle. All fits nicely inside. And of course the cell phone!
  29. BOWTIE BROWN
    BOWTIE BROWN
    BULLSHIT OR EXPERIENCE......
    I JUST TAKE THE OLE LADY , SHE KNOWS EVERYTHING.(batteries not included) NO , REALLY , SHE DOES.
  30. For my 55 Safari I carry the following:
    A 1 gallon gas can(empty and taped closed to prevent fumes escaping).
    A 1 gallon antifreeze bottle filled with water.
    A Craftsman plastic tool box (the thin briefcase style)with tools including a GM distributor tool.
    A pair of heavy gloves.
    A long heavy duty tow strap.
    4 small folding wheel chocks I picked up at a yard sale.
    A 10 ton bottle jack that fits under the frame even with a flat tire(I checked).
    An inflated spare tire(checked monthly).
    1 quart of ATF and engine oil stored under the hood in the old windshield washer reservoir bracket.
    A funnel with a 2ft long tube attached for pouring ATF stored in front of the radiator held in plce by the hood prop rod(an old sword cane my brother-in-law gave me for Christmas one year).
    Parts include:
    Points,condenser,rotor,distributor cap and ballast resistor.
    Fuel filter.
    3ft.length of fuel line.
    Hose clamp assortment(2 each to fit radiator and heater hoses).
    Several cable ties including long ones.
    Small coil of safety wire.
    Spare V-belt.
    2 good LED flashlights including one with a magnetic base that has a built-in red flashing LED display.Stick on fender to act as a warning flasher.
    A pair of safety glasses with built-in lights.
    A WORKING fire extinguisher.Changed every two years as are the ones in my garage.
    Most of the stuff is in with the spare tire.The A/F and gas cans are slid in beside the rear seat as is the tool box.The parts are stored under the rear seat.Which reminds me I have to replace the generator and starter brushes I had in my parts box.
    In the past 16 years I've logged nearly 170,000 miles on the car and have had very few problems.Had the rear U-joint bolts loosen up once;lost an inner wheel bearing in Boston;luckily a replacement was readily available.Reminds me I have to add those to my parts box;inners are NLA.Luckily I have 6 in my parts inventory.
    Radiator plugged up once;cleaned it out with Liquid Plumber on the road and it worked fine for almost a year afterward.Generator grenaded once almost setting the interior on fire(damn vent windows!).Luckily I found a replacement.Brake anchor pin lock fell off once(my fault)and ground the piss out of my new drum and the air shocks blew out on the same run.Both easy fixes once I got the parts.
