Technical Breathers VS Down Draft VS PCV?
Discussion in 'The Hokey Ass Message Board' started by TheSteamDoc, Nov 19, 2020.
  1. TheSteamDoc
    TheSteamDoc
    Wanting to dress up a Cadillac 390. The aluminum valley pan has no provisions for a down draft tube. I'm debating to install it or a PCV valve. What about valve cover breathers instead? Like to have one on each side mounted on the sides of the Offenhauser covers. What say y'all? Like something traditional. It'll be a rebuilt engine. Anyone do a PCV valve conversion on one?
  2. Jmountainjr
    Jmountainjr
    Well, from an engine protection standpoint, the PCV is far superior compared to the other two options. That being said, you could use the valve cover breathers with a PCV system. Two options. First option, both breathers as air inlets and install the PCV valve in the valley pan. Second option, use one breather as the air inlet and modify the other breather and hide the PCV valve in the other breather. Both will require a line from the PCV valve to the intake manifold or carb base.
    Joe Blow and TheSteamDoc like this.
  3. The breathers let air in while your PCV or Road draft tube is scavenging the crank case. breathers alone will not do the job. You just have to decide which you want to run road draft tube or PCV valve. The PCV is superior the road draft tube will do almost nothing at low speed.
    Center of the Galaxie likes this.
  4. Automotive Stud
    Automotive Stud
    I'd drill the aluminum valley pan, and either install the stock road draft tube back in it or try a pcv valve in it. I think the caddy valve covers are way to pretty to put breathers on.
    ekimneirbo, Tickety Boo and warbird1 like this.
  5. The reason all the OEMs went to locating the PCV and oil fills in the valve covers was to insure full air changes inside the motor. Using the valley pan/intake prevents this and promotes condensation in the valve covers, leading to sludge build-up. This is more true in high-humidity areas.
    302GMC, bchctybob, 30tudor and 2 others like this.
  6. Joe Blow
    Joe Blow
    Have vintage Offenhauser valve covers (no PCV ports). I came off my p***enger side breather with an inline PCV to the carb base. I used a breather screen as a template and cut a plate from sheet metal to plug the top of the breather and epoxied any voids around the edges to seal it off. I then stuffed the breather full with a stainless pot scrubber for a filter. The driver's side breather is unaltered so it's pulling across the engine, grabbing the crankcase pressure.
  7. 32Dan
    32Dan
    from Chino, CA
    What PCV part number did you use? Thanks, Dan
  8. Joe Blow
    Joe Blow
    AC Delco 19310783 or Standard Motor Products 112V which should be the same valve. Has 1/2" inlet and 5/16" outlet.
    32Dan likes this.
  9. Automotive Stud
    Automotive Stud
    OEM's stopped making engines with valley pans long before they went to PCV.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  10. Well, the PCV valve first showed up in '62. Ford built the Y-block until '64, AMC V8 though '65, Buick built the Nailhead V8 until '66, Pontiac V8 until at least '73, and Chrysler until '78 (B, RB motors). All used valley pans.
  11. TheSteamDoc
    TheSteamDoc
    Thanks Joe! The Dude abides.
    Just Gary and Joe Blow like this.
  12. ekimneirbo
    ekimneirbo
    Very nicely done.........;)
    Joe Blow likes this.
  13. 302GMC
    302GMC
    from Idaho
    The PCV valve has been with us since the 1930's. They were known as "Donaldson Valves", and used on virtually all HD truck, bus, & industrial engines.
    gimpyshotrods likes this.
  14. Joe Blow
    Joe Blow
    “I’m the Dude, so that’s what you call me. That or, uh, His Dudeness, or uh, Duder, or El Duderino, if you’re not into the whole brevity thing.”:p
    mario711, TheSteamDoc and Just Gary like this.
  15. Joe Blow
    Joe Blow
    Thanks man.
  16. Bandit Billy
    Bandit Billy
    Make that Pontiacs through 79. All my bandits had PCV and valley pans.
  17. seabeecmc
    seabeecmc
  18. hemihotrod66
    hemihotrod66
    Old front motor fuel cars just had breathers and that's what I have on my old hemi and they seem to work fine...
