Has anybody had experience with the TCI full pressure valve body. I'm planning to use in my 50 Merc with 350 engine and tri-carbs. I hopefully will eliminate the TV cable adjustment problem. Did you use their trans or add their valve body to your existing unit ? Thanks , Roger
I put a TCI trans with constant pressure valve body in my couisins 32 Vicky with 383 stroker.I am glad I didn`t buy it for my car.The shifts are way too hard.Unless you like chirping tires when it shifts get one. The cable adjustment is not that hard to do.
