Projects BRIAN MADE ME DO IT: 34 Roadster Build
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Nov 6, 2017.
  1.
    porkshop likes this.
  2. Bandit Billy
    Bandit Billy
    I didn't know that @Pist-n-Broke
    I guess it has been a while since I used him.
  3. 1946caddy
    1946caddy
    from washington
    Shelly Dogan from Longview used to do them (stick figures) in the 70's and I had Don King from Kelso do my Harley tank about 7-8 years ago. Don was a staple at the pin strip booth at the Portland Roadster Show but was absent last year due to health reasons.
  4. Bandit Billy
    Bandit Billy
    My daughter came and got her truck last night and that means my lift is clear! Time to address that transmission.
    dana barlow and Tim like this.
  5. Bandit Billy
    Bandit Billy
    I have to drop the engine and transmission in one piece, the last time I had it apart was several years ago and at that time I had to removed the front wheels in order to get the car low enough to set the engine in the cradle I built for this purpose. This time I am adding a 2x4 to the cradle so as to avoid the extra work.
    I am not a carpenter, I am more of a CARpenter but this what we have now
    The added 2x4s are attached using 8 aluminum plates I cut up and drilled. I also had the last bolts and washers.
    total cost of the refit = zip, zero, nada.
    After work tomorrow I’ll put it up in the air and pull it apart. Fun!
  6. Dick Stevens
    Dick Stevens
    The way the 2x4 is attached makes me a little nervous, but I don't know exactly how the engine sits in the cradle and how much clearance you have for possible better bracing.
    porkshop and Bandit Billy like this.
  7. Bandit Billy
    Bandit Billy
    Yeah, that thought crossed my mind. I fear they may want to spread. The engines oil pan rail sits on those 2x4s. This gets the weight of the blown Flathead and the T5 transmission. If it fails it would be ugly. I mean real ugly, real quick.
    perhaps a brace from the 2x4s down to the 4x4s?
  8. 40FORDPU
    40FORDPU
    I'd make 4 more of those straps for the insides of the 2x4's/2x6's, then drill thru the 2x4's and 2x6's and fasten with longer bolts/washers/nuts, that go completely thru, cradling the 2x4's.
    The 39 guy and Bandit Billy like this.
  9. This sounds like my kind of entertainment. Never heard of dropping a Flathead out the bottom of anything. And then it's only a little bit Top Heavy and that stand, uhhh! I mean what could possibly go wrong? I don't want to hear about it later or see it on U-Tube. I want to watch this in person. I'll bring my own Pop Corn and chair and stay out of the way. Is that Okay B-B?
    The 39 guy, Outback, patsurf and 2 others like this.
  10. Bandit Billy
    Bandit Billy
    That was the original thought, bolting through the wood with a bracket on either side but the brackets and bolt heads will mar the oil pan. There is little to know clearance for hardware in the middle. I have used the stand twice before and it worked well, just 3 " too short (insert favorite pun here).
    It is quite a sight buddy. You gotta remember I built it and I did so to remove the engine and transmission through the bottom of the car so I didn't have to fuss with the sheet metal removal. Radiator, hood, grille, it all stays in place. You just need this little crate and a 2 post lift. And it helps to load the lift with a bias toward the rear to compensate for all the weight that is about to drop out.
    Bring the recliner!
    The 39 guy, Pist-n-Broke and porkshop like this.
  11. Tim_with_a_T
    Tim_with_a_T
    Is there clearance to add some strapping to tie the left and right verticals together? Even Nailing in some nylon webbing in an X front and rear, or something, just to keep them from spreading apart.
    Or some sort of metal triangulated gussets:
  12. Bandit Billy
    Bandit Billy
    The first pic, no. The transmission will prevent it int he rear and I can't remember how much room there is in the front.
    The second picture is what I am thinking. Just to prevent it from wanting to spread those 2x4s. I don't think it will, the weight is going straight down but when I am wheeling it out from under the car if one wheel should snag something it could get it off balance for a second. Those "outriggers" would stabilize it. I have a 4 foot length of angle iron. I am thinking about making 4 one foot braces, welding which washers to the ends for lag bolts and racing the upper 2x4s to the 4x4s.
  13. I really like this idea.
    Outback and porkshop like this.
  14. If it was me, which it aint, and my multi-thousand $$$ engine/trans, which it aint..... I'd bite the bullet, measure up what you really need as a support/cart, make a sketch, and go steel tube shopping!!!!
    ANY amount of risk involved with a wonky scabbed together cradle is too f&#@ing much!
    Kind of like the old advice about shopping for a helmet...."if you've got a $50 head, put it in a $50 helmet, otherwise step up and make an investment!"
    Bandit Billy likes this.
  15. DDDenny
    I'm thinking with those reinforcements you should be good to go Bill.
    You may want to do an inventory on the "refreshment" cabinet in case anything goes sideways.
    That reminds me............
    Tim_with_a_T and Bandit Billy like this.
  16. Bandit Billy
    Bandit Billy
    I can’t disagree that this should have been welded together. I don’t like wood, welds for ****. But dance with the one that bring ya
    Emergency medical supplies are standing by in the electric medical cabinet in the garage.
    If this won’t hold it I’m out of ideas.
    this thing is more metal than wood! It’s a hybrid!
    das858, The 39 guy, Outback and 6 others like this.
  17. flynbrian48
    flynbrian48
    That ain't goin' anywhere...;)
    Outback, porkshop and Bandit Billy like this.
  18. Tim_with_a_T
    Tim_with_a_T
    Looks good! I'd feel comfortable with that.
  19. Dick Stevens
    Dick Stevens
    That is a big improvement!
  20. hotrodA
    hotrodA
    Whew! Looks great now that it’s braced. Breathing easier now.
    Show’s over, folks. Move along.
    Great idea dropping it out the bottom! Seems like it will save a ton of work.
  21. Bandit Billy
    Bandit Billy
    Moving forward!
    Here is how it sits on the rail
    very secure
    nothing to it.
    You know that old saying “if it unbolts chrome it?”
    there’s 100 bucks worth of fasteners!!!
  22. Tim_with_a_T
    Tim_with_a_T
  23. Bandit Billy
    Bandit Billy
    Stogy, Jim Bouchard, Outback and 2 others like this.
  24. Bandit Billy
    Bandit Billy
    The problem child.
    I found out the replacement transmission that I wanted is Ford not GM (like mine). That would require a new hogs head, clutch kit, hydronic TO bearing…basically another grand on top of their $3800 price before shipping. I ain’t doing that.
    I have the trans in my daily and will take it to a local shop that knows their way around these T5 s. Hopefully it won’t be apart too long. I’m kinda like Dr McCoy in that Star Trek episode where he replaced Spock’s brain. My smarts are temporary, the longer it’s apart, the longer it will take to figure out how to put it back together.
  25. atch
    atch
    b-t-w; I'm liking your engine cradle a LOT better now that it has those steel braces installed.
  26. Bandit Billy
    Bandit Billy
    I trust it more now. I was banging around on that ****** trying to dislodge it and it made me glad I spent a few minutes during up that crate. Hey, I have a crate motor?
    Jim Bouchard, Outback, Tim and 2 others like this.
  27. Tim
    Tim
    from KCMO
    Did you twap the straps and say “that ain’t goin nowhere!” Lol
  28. Outback
    Outback
    from NE Vic, Oz
    I missed the excitement, but glad it unfolded the way it did, without needing the medical cabinet! :eek::D Looking good!
  29. Bandit Billy
    Bandit Billy
    If I had a St Christopher I would have hung it on there. All good in the hood.
    Oh, I may have still filled a prescription or three but that's just daily protocol.
    The trans is at the shop undergoing surgery whilst I try my hardest to go back to the eye doctor. I pulled out my die grinder and sanding discs to address some unsightly areas of my flathead block and I got metal in my eye again. From the pain tonight, I will be on the phone with my DR for some eye cleaning tomorrow. Fun! And yes, I had my safety gl***es on. I don't know why this keep happening. I need to buy a new face shield. In fact, I'll go online now and buy one.
  30. Bentrodder
    Bentrodder
    from Cotati
