Hot Rods bringing my Model A pickup back after the fire
Discussion in 'The Hokey Ass Message Board' started by briz, Feb 13, 2021.
  1. briz
    briz
    I had painted the steering arms and was ***embling them when i noticed just how close a grease zerk fitting was to the steering arms. I noticed this when the zerk broke off as I tightened the steering arms.
    Okie Pete and Dave Mc like this.
  2. briz
    briz
    But the stub of the grease zerk came out easily with a very small E-Z Out. It spun right out by hand! I couldn’t believe it.
    Tim, Okie Pete, osage orange and 2 others like this.
  3. briz
    briz
    And I got my new front tires mounted. I finally 0C2E8336-A195-4A52-B6A6-7F024B71393E.jpeg decided to go with the 1935 Ford wires rather than the 60s slotted mags. And those are 5.50-16 Excelsior radials.
    winduptoy, clem, Okie Pete and 2 others like this.
  4. briz
    briz
    I decided to do a cable style clutch setup, so I got an early mustang pedal box. I wasn’t too keen on it for this application, and found a pedal box for a first- gen Bronco.
    Okie Pete, SS327 and Dave Mc like this.
  5. briz
    briz
    I don’t know why everyone isnt using these. Simple design, good size and uses what looks like mustang parts. Or so I thought.
    I had a mustang kit for a roller bearing conversion, but almost nothing fit.
    So here’s what I did. I milled out the pedal pivot to .815 in order to install the roller bearings.
    58CF4537-7014-4A2F-8C0D-3E9631F48369.jpeg DCC24F12-A12C-4DA5-850C-7A5E41C1E9E5.jpeg
    Okie Pete and SS327 like this.
  6. briz
    briz
    D60B636E-11AE-4D85-B49C-A63BAB77C6EC.jpeg I greased the rollers and re***embled the pedals. The pivot shaft on the early bronco is the same diameter, but longer.
    The fit was good, but there was some side-to-side play in the clutch pedal, so I fit some bronze shims that I found at a local hardware store.
  7. briz
    briz
  8. briz
    briz
    So now I have early Bronco pedals, a mustang T10 4 speed trans, and a clutch cable kit from a fox-body. but it’s all Ford stuff, so it’ll all just fall together in the Model A, right?
    I just got a clutch and have had the flywheel resurfaced, so I will start mocking it all together soon.
    winduptoy, 2Blue2, SS327 and 3 others like this.
  9. 2Blue2
    2Blue2
    Fun to see the 289 going in your rebuild.
    winduptoy and loudbang like this.
  10. briz
    briz
    I have a clutch, I have a flywheel, and I have a bellhousing. Beanscoot had said I might have a truck bellhousing, and it might be deeper than a car bellhousing.
    It is definitely not aluminum, it’s cast iron. But measurements I took seem to sync up w the depth of the trans input shaft. CD67BEC3-20EF-44A2-A48E-7FAFE904F5FC.jpeg
    winduptoy and Okie Pete like this.
  11. briz
    briz
    831C5485-C213-478F-A4C2-CB5498375B76.jpeg 246B908C-B1A3-4EE1-996F-0B4BB431A592.jpeg It looks like the pilot bushing will match up completely with the input shaft . 1958026E-7BF6-4711-BD4F-B70C9C4AFA04.jpeg
    Okie Pete likes this.
  12. briz
    briz
    I thought I would mock up the rest of the clutch and start to figure out how to get the cable linkage to fit.
    I didn’t get far.
    I could only get one bolt started because the bolt circle is 12 and 1/4 on the flywheel. The clutch is a 10 inch, so has bolt holes in a circle only about 11 inches in diameter.
    Bad news/ Good news: My clutch wont fit.
    But I can put in an 11 inch clutch that has more capacity.
    Okie Pete, SS327 and alanp561 like this.
  13. briz
    briz
    I wound up buying a great Ford Motorsport billet flywheel. I installed it with the 11 inch McLeod clutch. It’s a diaphragm style so I can convert to a cable style clutch linkage. And it uses 3/8” bolts instead of the 1/4” bolts used in the 10 inch clutch. So I’m feeling good about that.
    But I’m still struggling with fitting those 35 ford wires. The back of the wheels were just making contact with my calipers.
    winduptoy, Okie Pete and AHotRod like this.
  14. briz
    briz
    I had already modified adapters ( the center bore was too small) and got a good fit, but as it turns out they don’t move the mounting point of the wheel quite far enough either.
  15. briz
    briz
    So a friend of mine made some spacers from aluminum plate. Really nice. 1/4 inch thick.
  16. briz
    briz
    they sandwiched between the face of the hub and the adapter.
  17. briz
    briz
    I thought they turned out great.
  18. briz
    briz
    But I have one side very close and one side just kissing the caliper. I thought the interference was less than 1/8 inch but 1/4 inch spacers werent quite enough.
    Has anyone else had trouble adapting for the 35 Ford wire wheels? I really wanted to do disc brakes and Ford wires.
    But I do have a Plan B
  19. SS327
    SS327
    Thicker spacer, those look a little thin anyway. ;)
    winduptoy likes this.
  20. briz
    briz
    I need to modify the bellhousing so I got a fox-body clutch arm and pivot. The arm looked good but the pivot needs to be adjustable, so I made one from a good quality nut and bolt. IMG_2142.jpeg
  21. briz
    briz
    This was a very hard bolt, so rather than try to cut it on a lathe, I chucked it up in my drill. The head of the bolt looked a lot like the nut, but ground down pretty nicely.
    The grinding wheel was pretty soft, so as you can see, the bolt wore a rounded grove in it pretty quickly. That helped the arc to be consistent, I think.
    winduptoy, Okie Pete and impala4speed like this.
  22. briz
    briz
  23. briz
    briz
  24. briz
    briz
    I just eyeballed the placement, and drilled and tapped the bellhousing.
  25. briz
    briz
    After getting the bellhousing and trans back in, I thought I should finally do something about the shifter. The shifter wants to live right where my right leg is gonna be, so I got a new stick with an offset. When the new stick came in, I went out to install it. Just 2 bolts- easy as that, right?
  26. briz
    briz
    Except mine is an early model shifter that has the stick as a part of the pivot mechanism- the receiver, they call it. No bolts. It’s welded to it.
    I was all ready to start cutting and decided to do some research. I found some great howto videos and realized I could update to a receiver that uses a bolt on stick. Cool.
    The new receiver came as an ***embly, so it took care of some worn parts I found when I tore it down. IMG_2280.jpeg It’s kinda the same only different. It’s taller than the other stick, and has the dogleg to the right so It’ll fit me.
    loudbang, Okie Pete and impala4speed like this.
  27. briz
    briz
    The other thing I’ve been working on is fitting the dash. A dash brace was getting in the way, and after considering large hole saws and making my own dimple die, I just got a large ball peen BFH and took care of it.
    Tim and Okie Pete like this.
  28. briz
    briz
    Fortunately it didn’t need much, just a little for clearance. Now the dash sits nice.
  29. briz
    briz
    Something I forgot to mention- the new sheet metal in the floor and toe boards! There’s a repro underseat pan and some sheet metal instead of wood on the floor.
    I haven’t done anything to them except drop them into place. I’ll cut a hole for the shifter and clearance for the trans as I need, and then prime and paint them.
    I guess I am “credit card “ building this thing in places.
    But I would’ve just bought a wood floor kit otherwise, anyway. 71123248489__D5419FCA-E640-4056-9776-F9E4C8F75E03.jpeg
    winduptoy and alanp561 like this.
  30. stillrunners
    stillrunners
    from dallas
    Great work.....keep going !
