Broken bolt fun
Discussion in 'The Hokey Ass Message Board' started by curtiswyant, Apr 11, 2006.
  1. curtiswyant
    curtiswyant
    I've got three broken bolts where the trans member bolts to the frame on my '49 ford. I've tried an easy out but it broke. I'm weary of drilling or using a torch...I'll probably just make it worse. Suggestions? I might try welding a washer/nut and backing it out...:mad:
  2. Slonaker
    Slonaker
  3. wayfarer
    wayfarer
    I always just weld an oversize nut to the bolt and remove it like you said. They've always come out.
  4. fbomb_70
    fbomb_70
    from Wisconsin
    There's only 3 things that will work on broken bolts like that- piss and vinegar...and oh yeah...PATIENCE! I've actualy had a lot of luck with using a small punch or chisel to turn the bolt a little at a time.
  5. Buford
    Buford
    I've had some good results using a left hand drill bit. I learned the hard way to do that before I had it all "butchered". Good luck, Frank
  6. curtiswyant
    curtiswyant
    I tried the washer/nut method and it worked like a charm!
  7. Yup, and one I tried was a mere 1/8" in diameter, broken off clean in aluminum!!
    The reason it works so well is that the heat breaks the rust bond, while you are providing a method of turning it.
    However, if the bolt extends through, and is rusted on the other side as well, you should cut that part off first.
    Cosmo
