Technical Broken bolt removal
Discussion in 'The Hokey Ass Message Board' started by nickleone, Sep 9, 2018.
  1. Ebbsspeed
    Ebbsspeed
    And most of them young ones will then also get the experience of dealing with a broken E-Z-Out.
    Those damn things are harder than a *****'s heart!
  2. Blues4U
    Blues4U
    from So Cal
    I've removed many a broken bolt, and several broekn EX Out's as well. Actually, the EZ Out's burn out pretty easy with a cutting torch, it's not that bad.
    Working on heavy equipment, rusted and seized up bolts are very common. Anything working near the ocean get's real bad, so do tractors used to push sewage sludge around. Nasty stuff! Broken bolts are just part of the deal.
    Those drilled bolts the guy in the video made are pretty cool, good idea. But one thing he was not doing which really makes a big difference in getting broken bolts out, is to complete the hole all the way through the broken bolt half. If the bolt doesn't come out easily at that point, heating it and allowing it to cool will sometimes cause the bolt to shrink and come lose. Hitting it with some penetrating fluid while still hot can help, but if too hot can cause it to flame, so be careful of that.
    If all else fails, and you've got a hole drilled through the bolt, cut it out with a cutting torch.
  3. G-son
    G-son
    from Sweden
    Depends, Europe or US? I checked several european languages and they all say aluminium, while those lazy *******s across the pond don't use all the letters. :p
    56don, Blues4U and tb33anda3rd like this.
  4. clem
    clem
    A couple of good tips there.
    I've never had to use an easy out.
    My method has always been to drill a hole and tap in an old allen key, and turn it backwards. Never failed me yet.
    Created out of necessity, when living 30 miles out of town.(yes, - I am a farmer)
    Even my mechanical engineer (do it by the book) son, was surprised at how easy it works.
    VANDENPLAS likes this.
  5. You guys are missing the point. If you turn the Ez Out a few revolutions, it comes out easy. It will usually be a little shorter than when inserted.
    56don and Casey Riley like this.
  6. Hollywood-East
    Hollywood-East
    I worked in a machine shop(engine) when I was a kid, Very similar to your style, We used Key stock, Kinda the difference between a 12 point socket, And a 6 point... Broken bolt's was an hourly occurrence, An bee's wax instead of penetrating oil when heat is used.... An ******* screws, Always kick sideways with a chisel lightly...
  7. old sparks
    old sparks
    beeswax heated in then let to cool. also torch heating broken bolt red hot then hiting with a shot of compressed air . blows **** all over then chase with a tap. scary but I have done it and it works. old mans trick
  8. Blues4U
    Blues4U
    from So Cal
    Haha, try a cutting torch, gives you better control.
  9. MantulaMan
    MantulaMan
    ATF/Acetone, punch and drill a hole to match the extractor size. Quality extractors are important. I paid £60 (UK) for my German made CV ones. I got a 1/8th turn of flex out of it before this stud started to move.[​IMG]
    Sent from my SM-J320FN using Tapatalk
  10. old sparks
    old sparks
    not a joke blues for you. works very well. are you a millenial
  11. Harbor Freight has a set of what are called “transfer punches”, the go all the way up to 1/2”. They have a small punch right in the middle to center a dot right in the middle of the broken bolt. Makes drilling broken recessed bolts much easier.
  12. Fortunateson
    Fortunateson
    Yes. Check the spelling on the periodic table and then pronounce it properly!
  13. Fortunateson
    Fortunateson
    LOL!
