broken gas tank line fitting help
Discussion in 'The Hokey Ass Message Board' started by peter schmidt, Apr 6, 2013.
  1. Roger Walling
    Roger Walling
    It is possible to weld a gas tank safely.
    First, I do all work outside with plenty of ventalation. (and away from the cat)
    I Don't bother to try and weld a rusted out tank, it won't work.
    I drain mine out and then clean out with a good detergent to remove all the gas and drain.
    Then I fill the tank up with water. It must be completly full!!
    Then I turn it over and place the hole at the very top and refill through the hole displacing ALL the air. I then weld without a chance of an explosion as there is no air/fuel mixture in the tank.
    In the case of the tank in question, a small hole would have to be punched or drilled with an air drill to allow the trapped air to escape and for water to be introduced into the tank. After the line is welded, I would then weld the hole.
    Disclaimer!! This is not a recommedation for you to weld a tank.
    If you follow this procedure and the tank explodes, and kills you, Don't call me back, you have not followed my description carefully! .
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Roger, if they call you back after they are dead, RUN LIKE HELL !!!!! :eek::D
    Don
  3. peter schmidt
    peter schmidt
    from maryland
    Yea its not worth the risk for me to weld it i know its been done a million times but im not gona try my luck. thanks for the link for the mustang tank i think im gona go that route.
  4. oldolds
    oldolds
    Wow! What is the space number? In fact do they have an 800 number? Want to get my order in.:D
  5. Nope they would have at least used JB-Weld. :D
  6. jkeesey
    jkeesey
    I picked a 20 gallon tank 3 years ago for $20 and a 10 gallon tank last year for $10. You just have to look (not at the brand new parts stands).
  7. 51hornetdude
    51hornetdude
    from denver
    If you get desperate, I have a few extra Hudson tanks that are in decent shape for not a lot of money. Not sure what rules are on shipping used gas tanks though. It might be hard to get the smell out completely.
  8. oldolds
    oldolds
    I have checked those guys out over the years. Not much for "orphan" cars. They are a top 100 place. Only place for a original tank for cars like this is used or if a specialty supplyer gets a run made.
