Broken odometer, good speedometer??
Discussion in 'The Hokey Ass Message Board' started by fomoco1955, Jul 12, 2011.
  1. fomoco1955
    fomoco1955
    from socal
    I have a 55 fairlane with a working speedo but the odometer doesnt work. I figure its not the speedo cable since thats working. Any ideas on the problem/fix. New gear for the gauge??
  2. 325w
    325w
    Several internal problems could be the cause. The counter weight inside has a gear like a clock to drive the odometer. You might remove the speedo head and put some oil in the felt cup on the shaft. Most likely it will need a speedo repair man.
  3. 53 effie
    53 effie
    There is a gear that runs the odometer seperate from the speedometer. On my 63 Ranchero that gear is plastic and one of the little tabs that it spins on broke off. I don't know if yours would be plastic but I'm guessing it is a similar issue.
  4. MORRISGAUGE
    MORRISGAUGE
    The odometer carrier gear has likely failed or the worm gears are completely stripped. Sometimes odometers lock up and shear an internal carrier gear. Is the odometer wheel alignment straight?
  5. fomoco1955
    fomoco1955
    from socal
    Thanks for the info. Ya the odometer numbers are ligned up
  6. fomoco1955
    fomoco1955
    from socal
    Thanks. Ive seen that type of part offered from MAC's I'll look into ordering one. There cheap so if it doesn't work Im not out much before I send it to a speedo guy.
