Hot Rods Broken off studs in Aluminum.
Discussion in 'The Hokey Ass Message Board' started by Greg Rogers, Apr 21, 2023.
  1. Greg Rogers
    Greg Rogers
    Hi Guys, I was sooo impressed yesterday! I had 3 broken studs on some aluminum heads. The first one I tried to heat, drill with L/H bit, chip out, etc. Of course I did mess up the threads (but it will be ok). After cryin and whinin about that I slept on it and watched a YouTube video about welding a nut to the studs. I thought that wouldn't work before as the studs were broken off about 1/8" below the surface. But as guy on video showed, I could weld up a bump on stud with mig wire and then weld nut to that. Vawalla!! Works great!! Got those 2 out in a half hour with no damage to head. I know lots of you guys have done this before. I just wanted to let the guys who never have what a miracle repair it is!!
  2. egads
    egads
    It's spelled VOILA:):). Glad you got them out.
    Atwater Mike, 2OLD2FAST and Blues4U like this.
  3. Jmountainjr
    Jmountainjr
    Very common practice on newer stuff. I won't go into detail, but a popular newer Chevy engine with aluminum heads has an issue breaking exhaust manifold studs. This is the common removal practice. Perhaps that makes it YouTube material? But it also works on our old stuff. Aluminum is aluminum after all.
    Budget36 likes this.
  4. It's the heat what does it.....
    1-SHOT likes this.
  5. 1-SHOT
    1-SHOT
    from Denton
    I use that method with great results but I wait until the part has cooled completely down. If you try to get it out before it normalise they tend to snap off. It works on 10-32 bolts just takes a little practice and patience . Frank
  6. jaracer
    jaracer
    I've done it many times, but you need a good supply of nuts. It doesn't always work the first time. However, it has always worked in the end.
  7. On the stubborn ones it might take 2-3 tries.
  8. tubman
    tubman
    Try to use un-plated nuts. Cadmium gives of dangerous fumes.
  9. Jmountainjr
    Jmountainjr
    Take your zinc or other plated nuts and put them in some white vinegar overnight and the plating will be gone. You are correct about welding fumes.
    Atwater Mike likes this.
  10. dreracecar
    dreracecar
    from so-cal
    Muratic (pool) acid, removes the plating in seconds--- but do it outside near a water hose to flush off.
    True about the welding fumes, if you are doing it for hours, but a 1 time shot for 2 seconds is no big deal
  11. Jethro
    Jethro
    I can't remember the last time I drilled out a broken bolt. I have been doing the welded nut trick ever since I bought a MIG about 20 + years ago. In fact I used that trick to remove some wheel locks on my OT daily when I stripped the key socket.....I guess I'm too torquey.
  12. I had some broken bolts for the inspection cover on a SBC aluminum bellhousing. Used TIG and built up the broken piece. Grabbed that exposed ball with small vise grips and unscrewed it. Heat did it.
  13. squirrel
    timely thread, thanks!
    just used that technique this morning, only because you reminded me that it works.
    Atwater Mike and Doublepumper like this.
  14. pirate
    pirate
    from Alabama
    I know it seems counter intuitive but after welding nut try to “tighten” the bolt/nut whatever it turns sometimes just a few degrees and it seems to break loose he threads. Also a sharp rap on the broken stud/bolt with a punch and hammer before welding nut helps to break threads loose. Your mileage may vary.
    Algoma56 likes this.
