Technical Broken water fitting in block
Discussion in 'The Hokey Ass Message Board' started by 63401nailhead, Mar 26, 2023.
  1. 63401nailhead
    63401nailhead
    Today I was removing the factory style trans cooler from our 65 F100 to upgrade to something better. It’s got a 240 cid with a C4 (or cruiseomatic), and it was originally fitted with this weird setup that had trans cooler lines running into this small rectangle thing that has steel pipes with coolant running through them. One went to a T valve split into the lower rad hose, and the other threaded into the side of the block just above the starter. Anyway, everything went pretty well for being rusted to hell, except that the fitting that bolts into the block broke off. From what I can tell the threaded part is still in there. What’s the best way to fix this?
  2. Easy out should remove that.
  3. 63401nailhead
    63401nailhead
    Also just to note, I’m not going to reuse anything from the original setup, so I don’t need that hole there for anything anymore
  4. Budget36
    Budget36
    If access is available, drill/drill/drill then run a pipe tap to plug it off. Too oily to heat with a torch. An easy out might work, just don’t muscle it when trying.
    Boneyard51 and anthony myrick like this.
  5. 327Eric
    327Eric
    Start soaking it with penetrating oil as you contemplate your options
    Tow Truck Tom likes this.
  6. Don’t get crazy with an ease out. I busted an intake removing a busted fitting
    If it’s br*** that ease our will probably chew it up.
    It’s worth a shot but don’t bow up on it.
    If any of its sticking out, a punch could be used to collapse it inward.
    I used a mini hack saw blade to cut slits and a punch to collapse it.
    Budget36, alanp561, 2OLD2FAST and 4 others like this.
  7. harpo1313
    harpo1313
    from wareham,ma
    A fine tooth jigsaw blade will make short work on that.
    Budget36, alanp561, AVater and 2 others like this.
  8. A good quality set of these type extractors will be fine.
    irishsteve, ottoman, alanp561 and 4 others like this.
  9. CSPIDY
    CSPIDY
    Use a left hand drill bit
    vtx1800, jaracer and Desoto291Hemi like this.
  10. 325w
    325w
    Try a pipe ease out. They are different than other ease out.
    irishsteve, Budget36 and 2OLD2FAST like this.
  11. That’s br***,,,,,should be fairly straightforward to remove.
    Just take your time .
    Tommy
    Budget36 likes this.
  12. dalesnyder
    dalesnyder
    Those style ez outs that old timer posted will remove that br*** fitting with no problem.
    I use them all the time as a boiler mechanic.
  13. 63401nailhead
    63401nailhead
    Thanks for the advice everyone. I’m gonna pick up a set of ez outs and give that a shot. Never used them before, any tips?
  14. jaracer
    jaracer
    Don't buy cheap ones. (HF)
    But if you aren't reusing the part, why do you care about the broken fitting?
  15. My Buddy at work used to say the extractors from the Harbor will never cause you any trouble because they are made of wood.
  16. bill gruendeman
    bill gruendeman
    Best advice use caution and don’t get to heavy handed and take your time you will be fine.
  17. These are my favorite, they are square instead of spirol, that fitting will come out in seconds with one of these. Screenshot_20230326_190207_Samsung Internet.jpg
  18. junkman8888
    junkman8888
    In my experience, with br*** the best thing to do is, using some jeweler's files, file two slots opposite each other the depth of the fitting, then turn the fitting out with the proper size screwdriver.
    Desoto291Hemi and Budget36 like this.
  19. Give it a sharp rap with a hammer to shock the threads before using a quality extractor, and it should come out. Another option would be to simply cut internal threads in the broken ****** with a 1/8" pipe tap and screw in a pipe plug with sealer.
    irishsteve and ffr1222k like this.
  20. 63401nailhead
    63401nailhead
    It occurred to me that I never remember to come back and update my thread, so I just wanted to pop back in and say thanks for all the advice everyone. I was able to get it out today using the kit that 57ChevyMadMan recommended. I soaked it in PB blaster over the past week, used a whole can pretty much, and then today just before attempting to extract it I used a mixture of acetone and trans fluid, which I read about in a unrelated thread on the hamb.
    it actually came out pretty easily after I tapped the bit in with a hammer and slowly unscrewed it with a ratchet and a swivel extension. Today was a good day.
  21. SS327
    SS327
    I was going to recommend a SBC swap!
    '28phonebooth and Algoma56 like this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thanks for letting us know the outcome , Good on ya'
    Algoma56 likes this.
