Brookville Deuce firewall Fit
Discussion in 'The Hokey Ass Message Board' started by marfen, May 22, 2010.
  1. marfen
    marfen
    from sask
    Just wondering what your thoughts are on the flat Brookville deuce firewall as far as fitment go. I have an original for my real 5w deuce but am leary of cutting it up to make room for a 354 hemi.
  2. captain scarlet
    captain scarlet
    from Detroit
    I have one in my 3 window coupe. Fits pretty well I think.
  3. The Brookville firewalls dont fit too bad.How nice is your original?
  4. ratster
    ratster
    how much they cost? my buddy won one at Nat South
  5. swifty
    swifty
    You're going to have to cut into your hood too so what are you doing there?
    swifty
  6. thirty7slammed
    thirty7slammed
    from earth
    If he won it at an NSRA event, sure it's not for a pinto:confused:
  7. mickeyc
    mickeyc
    I have a flat Brookville firewall that I clamped to my three window body. The fit seemed fine to me. I also clamped a genie ford unit to the body and the fit seemed to be very close to being the same. I stood the two
    firewalls up against each other and the profile was very good. I plan to use the genie to insure proper body shape during body rebuilding efforts.
    The brookville unit will then be modified to allow setback of a 354 hemi
    motor. This should allow the genie to survive for some else to use.
  8. What is this the '32 restorers board?
    If you don't have one at all, buy a repop, if you have an original cut it up. Just my cranky old guy opinion....worth squat.
    Charlie
  9. krylon32
    krylon32
    from Nebraska
    Enjoy the fact that you have a gennie then do what you need to do to make things fit. There's nothing quite like original Henry steel!
  10. uncle buck
    uncle buck
    I have one in my tub. The fit is actually pretty good and there is more than enough metal to allow you to trim to fit in around the trans area. It also comes with new feet which you will have to fit and attach yourself. radiator support rod brackets did not come with it though. I'd buy another if I was building another deuce. Dave
