Technical Brought the Hydramatic Back From the Brink
Discussion in 'Traditional Customs' started by theold52, May 4, 2019.
  1. theold52
    theold52
    Hey guys. I have made a few posts this last week re the adventures with the 1952 Pontiac.
    The Hydramatic only had low and reverse. That was it. So today I figured better pull the pan and at least clean the screen. Lo and behold, two bolts lying there in the pan. One bent!
    So as I looked around, I see that the governor flange/rear pump is hanging barely by one loose bolt. It is normally held in place by two grade 8 bolts. The one had fallen out as a small piece of the cast case, cracked and fell into the pan. The other was on its' last legs and was about to spell disaster. I was unable to get a bite on the one. So, I cut a bolt to size, just enough so the head of it cleared the spinning governor. With drips of ATF in the face, (love trans work), I was able to place it up where the boss had broken and threaded it down. Lots of red loc***e and a nut secured it. Was able to get a decent 16lbs on the other.
    The rear drum had lost one of its' bolts. Six total I think. I spent an hour trying to snake in a replacement. No go. But five will work for now. Next, 11 quarts of ATF. Fired it up, and took five minutes for the Torus to fill. I do have the special Hydramatic tools for setting front and rear bands, and did so. Cracked a beer, couple of swigs, put 'er in gear, OK let's go. Perfect.! I now have all my gear shifts. I could not have had a better Saturday!
  2. BJR
    BJR
    Good for you to go for it and get it working again.
  3. 56sedandelivery
    56sedandelivery
    Probably one of the most recognizable transamatic automissions of all time, thanks to B & M (and a few others), and 60's era drag racing. Good luck in keeping it going; they were pretty tough in the day. I am Butch/56sedandelivery.
