Art & Inspiration brush/spray can paint jobs
Discussion in 'The Hokey Ass Message Board' started by rusty1, Apr 13, 2021.
  1. rusty1
    rusty1
    ...thot I saw a thread about this but can't find it now,...how about some brush/ spray can paint jobs...before & after if possible.
    ...here's my 55 pickup before and after it's $11.00 paint job,..$8.00 quart of Walmart house paint and $3.00 brush, I distress'd it a bit...not for everyone, but good enuf for me....this was just regular flat latex house paint and a $3.00 general purpose brush. I think it looks much better than how it looked when I started putting this truck together.
  2. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Jake's Tub comes to mind.
    rod1, Rawrench, deadbeat and 13 others like this.
  3. On the up side......you can park anywhere you want.
    clem likes this.
  4. deathrowdave
    deathrowdave
    from NKy
    Jake at one of his best moments ! This was way before the trend of hanging things from the rear or this would have to large br*** balls hanging from the rear ! This is the definition of true Hot Rod fun in the simplest form
    rod1, Kelly Burns and AHotRod like this.
  5. Bugguts
    Bugguts
    My $22 paint job.
    My 77 year old buddy slid this A into the ditch backwards and ended up on its top. I fixed it for him and suggested a brushed paint job to keep costs down. He was totally cool with it.
    It was $10 Rustoleum and a $12 brush.
    Normally my paint jobs are $$$$, but, this one was fun and practical. 20201218_161010.jpeg IMG952679.jpeg 20201226_123808.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Sharpone, Rawrench, deadbeat and 20 others like this.
  6. Blues4U
    Blues4U
    from So Cal
    My truck has a driveway rattle can paint job.
    Before:
    After:
  7. Casey Riley
    Casey Riley
    from Minnesota
    Is that Krylon True Blue?
    Thor1 and Blues4U like this.
  8. chessterd5
    chessterd5
    from u.s.a.
    Me too. Brushed rustoleum.
    Playing around with adding some flames!
  9. Blues4U
    Blues4U
    from So Cal
    Haha, it's Krylon True Blue as a base coat underneath Krylon Shimmer metallic Jazz Blue, coated with 2K rattle can clear. Here's a better view of the color:
    rod1, Sharpone, Rawrench and 17 others like this.
  10. indyjps
    indyjps
    Id rather brush one than rattle can.
    The regulations dealing with rattle can paint and airborne contaminants have forced manufacturers to remove so much its nothing but a can of tinted piss.
    If you want to rattle can, its worth the trouble to have a paint supplier load cans for you, usually enamel, usually the fleet line of a real industrial / automotive paint company. Stay away from the home improvement store versions.
    With a brush job, I know what the paint actually is and can add hardener. Rustoleum in quarts with enamel hardener is tough stuff and will buff out, takes a long time to cure.
    Lets see some pics
    Sharpone, Chucky, AHotRod and 3 others like this.
  11. If your going to rattle can use a preval sprayer instead.You can use better paint,and add hardener.
    Sharpone and fourspd2quad like this.
  12. dutchrod
    dutchrod
    My coupester just brush painted (no polish) with enamel paint from Craftmasters Paint in the Uk.
    This paint really flows nice and y
    You don't see brush strokes when dry.
  13. Japan drier helps oil paints flow well with a quality brush. Real coachwork skills. You can lay down an amazing trad paint job down that way.
  14. Flathead Dave
    Flathead Dave
    from So. Cal.
    I get my custom color from the paint shop that I go to in Riverside.
    At $25 a can I have to be careful with it.
    They load the rattle can with
    my custom color, Prismatic Flame Red.
    Worth every cent.
    Sent from my SM-G973U using The H.A.M.B. mobile app
    Sharpone, AHotRod, mitch 36 and 3 others like this.
  15. Chappy444
    Chappy444
  16. BLACK STUDE
    BLACK STUDE
    The stude after 22 cans of valspar red and black satin. No body work, no sanding, just wiped it down with lacquer thinner. Couldn't get the stuff off when I finally did the body work and painted it black later. I was amazed how heavy you could lay that rattle can paint on and it not run. I would definitely use it again for a quickey paint job. IMAG0101.jpg IMAG0309.jpg
    Sharpone, brEad, chessterd5 and 10 others like this.
  17. Rusty Heaps
    Rusty Heaps
    8BF7518E-4E20-450A-90FC-086D49690F0C.jpeg 62CDF2D0-BF91-4A81-9B3F-149FD48E9036.jpeg 7335C249-D43A-46D1-9E7B-0337A81FF8D2.jpeg 379AD47B-B17E-4BFE-A979-BA942F5F1B35.jpeg ABBAEBCA-6040-4B08-A738-C193E30C0DF6.jpeg ‘55 Pontiac, rattle can white upper, ‘52 Buick, rattle can roof and red body panels, ‘46 Chevy, satin black rattle can, compounded and waxed. The ‘46 looks nearly like an original lacquer job.
    Sharpone, deadbeat, AHotRod and 11 others like this.
  18. rustydusty
    rustydusty
    Here's the rattle can "flat black" paint job on a '50 Dodge as I bought it. So horrible, even a "r@t rodder" wouldn't have liked it. A compressor and spray rig is a good investment with lots of other uses. Eventually I sprayed the Dodge with primer before trading it for another car... 974.jpeg 742.jpeg
  19. mitch 36
    mitch 36
    My Chevy used to be red and black lacquer. I sanded it all off, rolled on 2 coats of Rustoluem rusty red primer and 2 coats of satin hunter green followed up with one coat of green with an expensive brush. The fenders were brushed with Rustoleum satin black. I used Penetrol with every coat so it flowed out nice, it still has SOME brush lines but I'm VERY happy with it. Less cleaning, more driving and it still looks presentable. 20170530_141920.jpg IMG_0586.JPG
    Sharpone, Rawrench, Cosmo49 and 15 others like this.
  20. Blues4U
    Blues4U
    from So Cal
    VERY presentable I'd say. Good job!
    Sharpone and mitch 36 like this.
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    garage rattle can paint job... Roof fake bare metal touch with spray cans. 53-28.jpg
    Backyard Paint job
    Sharpone, deadbeat, AHotRod and 7 others like this.
  22. mitch 36
    mitch 36
    THANKS,,,,My best friend is a paint/ body guy and he was very very very upset that I was not spraying "SHINEY" paint. We went round and round but when he saw how it turned out he actually conceded that he liked it. :) :) Mitch
  23. 1971BB427
    1971BB427
    from Oregon
    My first vehicle was a 1947 International panel truck I bought from my uncle before I could even legally drive. I saw it sitting behind his barn, and asked about it. He ended up selling it to me for $25 in 1964. He had painted it with enamel brushed on in a dark blue, and it had sat outside all the time. After I got it running, I borrowed a buffer and bought some cutting compound and buffed all the oxidation off it. When I got done what few brush strokes were on it were almost gone, and it looked gorgeous. I rattled can painted the fenders and running boards gloss black, and the panel was eye catching! Everyone who saw it thought it was a gorgeous paint job.
    Sharpone, AHotRod and Casey Riley like this.
  24. steve hackel
    steve hackel
    Just adding something here..... Going back to when I was college, I remember reading an article in science cl*** regarding a spray can paint job done as multiple segments, and it was by a prominent custom shop. About the Fall of 68 or 69, and possibly hot rod or car craft magazine? They had ordered all the spray cans from the manufacturer in the batch number, including their primers and clear. Probably lacquer.
    Body work, primers and paints, wet sanding, and clear coats. If someone can locate this article, it might be a great reference to post here.
    Sharpone and AHotRod like this.
  25. 4ty
    4ty
    Back in the late 50's I painted a Model A with a brush and Rust-o-Leum. Also used an Electroluxe vacuum cleaner to spray lacquer primer. Both in the driveway.
    Paul in CT
  26. 40FORDPU
    40FORDPU
    Brush painting a car may be just the ticket in some cases..traditional, inexpensive, and practical (no paint booth, no neighbor complaints, HOA'S etc.).
    To get a quality type of result, there is a lot of work (cutting and buffing) involved after the paint has been applied to the surface, which would be the case in either applied top coat, knocking down/flattening orange peel, or brush strokes.
    I've never done it, but I "get it".
  27. typo41
    typo41
    I am over in Mentone,,, what shop do you use???
  28. Budget36
    Budget36
    So what style/type, etc of brush gets the best results? Or does the type of primer and paint come into play?
    Sharpone likes this.
  29. This also done with Craftsmaster using Purdy brushes. Technically, it's Tekaloid and the brush marks drop out as it dries. If you leave it long enough you can buff it but it dries very glossy.
    Preparation is important and you won't get a finish like this just slapping it on. If only I had a dust free booth.... IMG_20200405_145846864.jpeg IMG_20201010_132516470.jpeg IMG_20210401_163321756_HDR.jpeg IMG_20210322_175304168_HDR.jpeg
    Sent from my moto g(8) using The H.A.M.B. mobile app
    Sharpone, vtx1800, AHotRod and 7 others like this.
  30. GordonC
    GordonC
    Here's the 32 hood top I did up for my 31 A roadster. I rattle can sprayed it with Rustoelum black and it sort of kinda matched what I already had on the body.
    Sharpone, Rawrench, clem and 12 others like this.
