Bubble balancer??
Discussion in 'The Hokey Ass Message Board' started by Killer, Dec 28, 2003.
  1. Killer
    Killer
    Do you balance both sides of the wheel/tire or just one side???
  2. Sam F.
    Sam F.
    im pretty sure its just the outside,at least thats the way i was shown.
  3. manyolcars
    manyolcars
    The bubble balancer works well for skinny tires, put the weight on either side. Modern tires that are very wide require weights added to both sides.
  4. Jimv
    Jimv
    best thing to do is lay the weight on one side to get it balanced & then add it to both sides, if its an ounce split it & put 1/2 oz on each side.if its a small amout you can put it on one side.
    Jim
