Bubbles in fuel filter
Discussion in 'The Hokey Ass Message Board' started by lgh1157, Jun 9, 2011.
  1. lgh1157
    lgh1157
    SBF - 289.
    Rubber line from tank - Steel line along frame - rubber to pump - rubber to carb.
    Vented tank - [ not blocked ]
    Fuel line is not near any exhaust or manifold.
    Once warm i get sporadic bubbles in the filter. The engine does not stutter, it will "drop" a very little at idle, but will not die.
    I did buy one of those $10 gl*** filters that break, im gonna replace that first.
    Is this vapor lock ? , if it was i would figure the car would start to run really rough.
    Could the fuel pump be on its way out ? if so i thought it would be also running rough
    Thanks
    L
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Might be that POS gl*** filter ****ing air
    some air in the filter is normal also
    if its running fine, than i wouldnt worry about it.
    Id still change that filter
  3. badshifter
    badshifter
    Is the filter on the suction side or pressure side?
  4. noboD
    noboD
    A loose fitting can "pull" in air but not leak gas out.
  5. lgh1157
    lgh1157
    Pressure - between Pump and Carb
  6. lgh1157
    lgh1157
    That's the problem , once hot , it will stutter in traffic to point of being stressful .
    I'm pretty sure its vapor lock , gonna look into running a return line
    L
  7. sdluck
    sdluck
    Check fuel preuusre,low pressure will cause vapor lock
  8. low budget
    low budget
    from Central Ky
    It isnt water bubbles, is it?
    Part of my (I thought) vapor lock issues was just junk in my old tank.
  9. badshifter
    badshifter
    You can run a temporary gas can with a new hose from the suction side of the pump and see if you still get bubbles. It sounds like air leaking in on the suction side. Could be the sock on the p/u is plugged. I'd byp*** the stock tank for a test ride and work from there.
  10. lgh1157
    lgh1157
    Replaced the filter, put a new pump on there. Took of gas cap, tightened all fittings, . . . . . still got the bubbles, definitely gas evaporating , also check the steel line running down the frame, it is not near any heat
    L
  11. mart3406
    mart3406
    from Canada
    A portion of the rubber hose might be going
    porous from age. If the hose is on the suction
    side of the fuel pump, air will seep in - but
    fuel might still not seep out.
    Mart3406
  12. badlefihand
    badlefihand
    If it runs ok. Best get rid of the gl*** filter.
  13. BJR
    BJR
    Does it still have bubbles in the filter if the tank is full? If not the pickup tube in the tank is cracked or has a hole in it.
  14. lgh1157
    lgh1157
    replaced all hoses
    Replaced filter
    Still got these bubbles
  15. KULTULZ
    KULTULZ
    Bubbles (and partially filled filter) are normal. You would have to isolate the line(s) and run a vacuum test to ascertain they are air tight.
    Vapor lock happens on the suction side of the fuel pump. Fuel percolation is the evaporation of fuel in the carb bowls/inlet line if there is significant heat soak. More common is blend separation (again suction side) as today's gasoline is blended for EFI.
    Cavitation will also occur in a filter installed on the suction side.
    As mentioned, you need to verify pressure and volume delivery.
  16. lgh1157
    lgh1157
    So the bubbles aren't hurting anything ?
    Should i still look at installing an electric fuel pump ?
    L
  17. KJSR
    KJSR
    from Utah
    Good advice right here. If you are looking to throw money at a problem that isnt there feel free to send me some. The bubbles are normal....
  18. ddawg16
    ddawg16
    from So CA
    I also agree with the vacuum test.
    Pull the line off the tank...plug it....then hook up a vac pump....bet you have a leak....could be a pin hole in the metal line....especially if it's old and rusty.
  19. Sheep Dip
    Sheep Dip
    from Central Ca
    And if ya got any left after throwing some KJSR's way .....I'll take some...ditto on the normal for bubbles
  20. KULTULZ
    KULTULZ
    The bubbles are normal as a result of a suction type mechanical fuel pump.
    A properly installed and rated electric pump will pressurize the system and alleviate most problems with modern fuel.
    You can take it a step further with a regulated return line with either type pump.
  21. luckyuhaul
    luckyuhaul
    Perfectly normal...
    Every see through filter I've had on carb'd engines , cars and bikes, has had air in the filter. Probably because they are vented. You will not be able to eliminate them.
  22. d2_willys
    d2_willys
    from Kansas
    Detergent in gas, makes bubbles? LOL
