Projects Bucket list Belly Tank build
Discussion in 'The Hokey Ass Message Board' started by 53kemper, Nov 21, 2022.
  1. 53kemper
    53kemper
    Decided to see if I can build a 50s belly tanker this winter. Always wanted to build one. It wont be SCTA specs. More of a nostalgic build. Picked up a FJ-4 Fury tank yesterday. Have a running 8BA that I will be refreshing up and some 39 wide five running gear. Any ideas or tips would be appreciated. Thanks
      681.6 KB
      485.4 KB
      399 KB
  2. 26 T Ford RPU
    26 T Ford RPU
    I'm building one too so will follow along. :cool::) JW
    saltflats and 53kemper like this.
  3. Bearing Burner
    Bearing Burner
    from W. MA
    How big is the diameter of the belly tank? From picture it looks small.
  4. Rehpotsirhcj
    Rehpotsirhcj
    Watching
    Mine hangs in the rafters
    26 T Ford RPU likes this.
  5. 53kemper
    53kemper
    Tank measures 13' long and 25" wide center. I think I can squeeze everything in there.
    saltflats and 26 T Ford RPU like this.
  6. 26 T Ford RPU
    26 T Ford RPU
    Do you have a parts list for the build ? JW
  7. 53kemper
    53kemper
    Not really, Just building and getting parts as I go. Have the suspension, motor and trans. Will build a frame per the inside dimensions of tank then build on that. I'm guessing there will be a lot of fabricating that will keep me busy as I hunt down parts that are needed.
  8. 26 T Ford RPU
    26 T Ford RPU
    Be careful how you start as you run out of space very fast. JW
  9. 53kemper
    53kemper
    Breaking down the flathead. Aside of some water in one of the cylinders she looks pretty good and everything spins freely.
      473.5 KB
      349.5 KB
  10. 53kemper
    53kemper
    Finally back to building the tank. Getting ready to cut her in half today. Not sure what side I want to be up. Any input would help. Trying to figure out the best look but also what works best to fit everything in it. Decisions decisions?!?!
  11. Bentrodder
    Bentrodder
    from Cotati
    IMO the second pic looks more right.
  12. 26 T Ford RPU
    26 T Ford RPU
    The second pic looks best....BUT.... that may change if it has a fairing going on the top, good to see you making a move on it. JW
    VANDENPLAS likes this.
  13. 53kemper
    53kemper
    Hmmm. This is going to be a little work. May need to get me a plasma cutter to get at this.
  14. 53kemper
    53kemper
    Well I finally managed to get her cut open today. F8F1BB82-04D7-43CA-9D22-F28561ECF200.jpeg
  15. brady1929
    brady1929
  16. saltflats
    saltflats
    from Missouri
    Nice job, what did you use to cut it?
  17. 53kemper
    53kemper
    Used a Sawzall to cut the outside. Went through it like ****er but when I got to the two baffles I had to use a plasma cutter. Not easy getting in there around the channel but managed to gut it out.
  18. 53kemper
    53kemper
    Little bit of progress yesterday
    swade41 and 26 T Ford RPU like this.
  19. 26 T Ford RPU
    26 T Ford RPU
    Cool, have you tried sitting between the rails and is that engine going to slide in behind you. Nows the time to check. Looks nice. JW
    53kemper likes this.
  20. 53kemper
    53kemper
    Well finally got a new to me Merc Flathead. Tore it down and sent it off to H&H for some machine work.
  21. 53kemper
    53kemper
    Also got the garage all cleaned out to make room for the project. Have some rails I bent and a mock up BA to see how everything is going to fit. Time to start moving on this tank.
  22. Bearing Burner
    Bearing Burner
    from W. MA
    Having spent too many years building a rear engine lakester I have a couple of suggestions. One get the frame up to waist height on rugged saw horses. build a jig to build the frame on so that the frame rails are parallel and the cross members are at right angles to the frame rails .and you can get the front and rear axels on center and parallel
  23. 26 T Ford RPU
    26 T Ford RPU
    Cool to see you moving on your Tank, here's some inspiration. :) JW
    Kelly Burns and Tim_with_a_T like this.
  24. 53kemper
    53kemper
    Thanks for the advice Bearing.
  25. 53kemper
    53kemper
    26 T she looks great. How does it run?
  26. 53kemper
    53kemper
    Did some mock ups today, think I'm going to take Bearings advice and get the frame up higher. Waiting on some more parts so I can keep going.
    swade41 likes this.
  27. 53kemper
    53kemper
    Just went and checked out your build post again. My god that tank is awesome. Nice work
  28. 26 T Ford RPU
    26 T Ford RPU
    Don't know yet, maybe a couple months away on that and i will try it with the engine as is for a test, Then build it. JW
  29. 53kemper
    53kemper
    Little more mock up.
  30. Dave G in Gansevoort
    from Upstate NY
    My god, man! You let household stuff into your garage! And neat! And laundry facilities in the garage! It's not right, it's just not right!
