Technical Budget Friendly Fuel Pump
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Aug 31, 2025.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    I run the tried-and-true Carter 4070 in pretty much everything. 4-8 PSI, a whopping $71 on Amazon. I've put tens of thousands of miles on them without a hiccup. I also keep a little cheapo Chinese in line ticker pump in the trunk with long leads with alligator clips. That way if I'm ever out and the pump does finally die on me, I can put the ticker pump in line under the hood, and connect the alligator clips to a ground and the coil and get home. That saved my *** years ago driving from Gettysburg, PA back home to NJ. It doesn't have to work forever, just enough to get you home. And that worked flawlessly for those 180 miles.
  2. Dan from Oakland
    Dan from Oakland
  3. Casey Riley
    Casey Riley
    from Minnesota
    https://ebay.us/m/RcSPMG
    I run this. Made in USA. They are extremely awesome.
    The one I have on my Hornet Ive run the pump out of gas at least 5 times which is usually the kiss of death for electric pumps. Ive owned several of these and they are good.
    Tow Truck Tom likes this.
  4. ‘28 RPU
    ‘28 RPU
    Willys 36, I have had good success with the Carter pump (in the past) but I think that the “Made in China” thing is the kiss of death for virtually all electrical components. Everything from China is **** and their electrical stuff is the worst of all. I would suspect that the coating on the armature was related to ethanol fuel. If I could find an NOS made in USA Carter pump I would probably buy it but no thanks to Made in China. That barrel shaped Facet pump looks like a possible winner, it appears that it’s made in the US. Unfortunately my 89 year old aunt was badly beaten and is in the hospital. My playing with cars is over for a spell.
  5. I use Toyota Pickup truck fuel pumps they are compact, round, attach with one clamp, and are reliable.
  6. ‘28 RPU
    ‘28 RPU
    John, i will look into that, in general Toyota makes quality parts.
    I will be out of time for some time so will not be able to actually work on my project but i can still do research.
    I looked at the “Vapor Separator Fuel Filter” which includes a ****** for a return line to the tank. I have heard of them for years but I just now looked into them. They include a 1/64” orfice in the return ****** so that pressure is maintained to the carb but vapor can return to the tank. This is basically the system I was planning to use except that it uses a fixed orfice instead of the adjustable orfice (needle valve) that I was planning. This filter was OEM on vehicles from multiple manufacturers including AMC and MOPAR (the MOPAR system includes an orfice in the return line so the filter does not have an orfice built into it).
    The fact that this system was OEM would validate the concept that I was contemplating.
    That’s good news.
  7. Pa G.
    Pa G.
    from CT
  8. ‘28 RPU
    ‘28 RPU
    Pa G, and Casey, I had seen that pump and thought that it looked like a good possibility. I appreciate that you shared your positive experience. Thanks, Don
  9. Roothawg
    Roothawg
    I would have said Carter, but I have had 2 failures in the last few years of the same pump. If it were not set up for the Carter (mounting wise) I would look for something else.
    I have started going with the Walboro, in tank pumps lately.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    are in tank pumps more reliable? Maybe because they are submerged and fuel cools them?
  11. Roothawg
    Roothawg
    That’s the theory. Quieter also. That’s why all of the late models have moved away from frame mounted.
  12. GuyW
    GuyW
    And the advice for in-tank pump use is that one does not run them under 1/4 full tank, as the cooling effect is diminished and the likelihood of pump burn out is up. My off-topic PU has 2 tanks, so its easy to go to the other tank at 1/4 full, but it would be a pain with a single tank...
  13. Roothawg
    Roothawg
    My wife has never kept one over 1/4 tank, regardless of my pleading. Our 2002 F150 still has the original pump. 165,000 miles and 23 years on it. That statement ought to kill it dead…
    jet996 likes this.
  14. 19Eddy30
    19Eddy30
    from VA
    Yes & No , this is why They whet to sump Around fuel pump so Return fuel to keep pump cooler
    427 sleeper likes this.
  15. Toyota pickup truck electric good reliable and cheap to buy.
    GlassThamesDoug likes this.
  16. BigRRR
    BigRRR
    Any more info on the Toyota pumps you all are using …
    Year, model, engine?
    Thanks,
    Ron
    MMM1693 and 1biggun like this.
  17. Pass The Torch
    Pass The Torch
    They don't like heat. I ran one / replaced several on my '33. Yes, installed correctly and away from exhaust, etc. Would eventually get real hot and drop pressure to 2 lbs or so (in line gauge told me so). After about 15,000 miles I finally gave up and installed a mechanical Carter. Been smooth sailing ever since, and I drive my ****!
    Consequently, same pump on my '37 - no issues. Go figure! Both running SBC.
    Roothawg likes this.
  18. Been a while since I put one on my 51 Merc with SBC but I think they came 6 or 12 Volt, 3 or 6 Lbs pressure output, they are about 4 in long, 2 in round, come with a mounting clamp and want to be back near the gas tank, originally on mid 80's Toyota pickups.
