Technical Budget Motor, reusing a cam
Discussion in 'The Hokey Ass Message Board' started by lewk, Apr 29, 2022.
  1. Roller cams last forever. If I had to go by the pics only I would clean up #1 and run it on a get it going now and run it build. I actually would not be afraid of #2 just make sure it had no serious burrs. The pits are not optimum but the cam would do in a pinch.
    I was a cam short of putting a bike together in the '70s. I was on a close turn getting on the road and making a run. I had a roller cam on my bench that I took out of a '38 model bike for a cam change and it worked in my '49 model bike for several years.
    I know we don't do bikes here anymore but this is a cam discussion at this point and a cam shaft in a 4 stroke internal combustion engine is a cam shaft perhaps less lobes but still functions the same.
    TA DAD and lewk like this.
  2. lewk
    lewk
    from Mt
    My buddy who’s good at talking me into stuff dropped by yesterday and had a look at the motor. His take was that I have the cam(s) and the lifters, they’re the expensive parts. I’ll need a reinforced timing cover, a ****on, and pushrods. It’s a cheap motor and if things start to go south, I’ll hear it. If the cam ****s the bed and I go flat tappet, I’ll only really be out the cost of the ****on and pushrods as the timing cover can be reused. If things go really wrong, I’ve got a couple 283s that could be freshened up pretty easily. When I say a cheap flat tappet, I’m most likely looking at one of the Summit Cl***ic grinds. I’ve got one in a 63 327 that’s been hanging in there since ‘98.
    The El Camino was supposed to be a rough car that I could run around in and not worry too much about in parking lots. Once I got into it, the frame was bent and the rust was worse than I thought. I’m spending lots o money getting it right enough to put into primer. If I wait properly rebuild a 348, $$$$$$, it will be a long time before this car ever moves. If I build a humble 350, I might drive it this summer. If I nuke the motor, I’ve got all winter to work out a solution.
    Cam 1 seems to be some oddball custom grind and smaller. Cam 2 is a 12-422-8. 270/276 0.495 int./0.502 exh.
    I think I’m going to reuse a cam and see what happens. I’m doing it for science…
  3. warbird1
    warbird1
    Where is all that metal going to go if that cam goes south? You might find you'll be out a little more than just the cost of the ****on and pushrods...
    I've run used cams & lifters before without any issues, but that was back when we didn't have all the problems with those parts that we do now.
    lewk likes this.
  4. JOECOOL
    JOECOOL
    I have no idea where you are but locally here I know a guy who does dyno work . Quite often someone has him try several different cams to find the best one. He usually has a dozen left over with lifters on the shelves ,some are free. The rest are dirt cheap. check a rebuilder ,talk to a racer.
    lewk likes this.
