Buick 215
Discussion in 'The Hokey Ass Message Board' started by RustikRods, Jul 19, 2005.
  1. Triumph also used this 215 in its TR8.
  2. d2_willys
    d2_willys
    from Kansas
    What is going behind the 215? Not too many choices if bell pattern is still original 215 pattern.
  3. phongshader
    phongshader
    from Ca
    There is a conversion to use a Buick 300 crank that adds .6" stroke, 2.8">3.4", but the flange for the flywheel is a bit longer than the stock crank so there's a bit of customizing needed to make it work. Would the P76 crank work as a way to increase the stroke with out needing a special flywheel and rear seal/adapter?
  4. Bungi
    Bungi
    Guys -
    Heres an old photo of my 215 Buick project, a MG Midget, stock 4 barrel even fits under the stock hood with 1.5" to spare. Had to modify a Rover starter cause they have the solenoid on the side to clear the frame rail. Also had to send to England for a racing Rover remote oil filter block-off plate cause stock the spin on filter sticks out the front at an angle and would be right in the front crossmember. Working on rebuilding the trans tunnel and firewall at the moment.
    Later
    Rick
    Wisconsin
  5. Here is a picture of my Olds 215 in my 26 Model T sedan. I'm using a D&D adapter and a small bell housing 700R-4 out of a Chevy S10.
  6. 29 rattrap
    29 rattrap
    from New York
    if you wanted the crank out of a 300, i have one. id let the whole motor go for a small fee.
  7. fullhouse296
    fullhouse296
    from Australia
    hotroddon. Then you added to a 4yr old DEAD thread eh ! 40yr old p76 v8 motor .fully polished block,heads,manifold and bellhousing. Not rod related obviously .My apologies.
  8. fullhouse296
    fullhouse296
    from Australia
    And my first and only foray into overhead valve type of motors is smacked down ,followed by another twelve members ,BWAAAAHAAAAA .
  9. F&J
    F&J
    i don't care if it is an old thread :) I looked at the 2x2 link posted, then browsed that web company and saw this. I am speechless.
  10. Harry Bergeron
    Harry Bergeron
    from SoCal
    I think Roger Pensky ran something like that on his Zerex Special Can-Am car circa 1964. IIRC GM gave him some motors and technology.
  11. CJ Steak
    CJ Steak
    from Texas
    Buick/Rover 215's sound wicked! Cam the hell outta it and rev it past the moon.
  12. Now that looks (and sounds) like fun, is it yours?
  13. langy
    langy
    Rovers are very expensive to tune here in the uk, they also have some poor design in them, in my opinion the only good thing about them is their light weight.
  14. Thats because y'all put oil in your carbs! ;)
  15. kwoodyh
    kwoodyh
    Not up to your "Lucas" design standards? Which part isn't designed well? Rover bought the tooling about 50 years back and has been using it ever since, but still it's a poor design? Elaborate kind sir.:D
  16. T2Vracing
    T2Vracing
    from Arivaca
    I'm working on a tr1800 POB stroker rod . Aluminum body Aluminum engine can you say light and funky looking.
    T2Vr:rolleyes:
