Buick 215 ?
Discussion in 'The Hokey Ass Message Board' started by Empire32, Oct 4, 2005.
  1. Empire32
    Empire32
    from FRANCE
    Can you let me know what do you think about the Buick 215 (1961) v8 ?
    Parts availability, perf parts, parts pricing, opinions about the engine, etc...
    thanks !
  2. marq
    marq
    Or as we call it in the UK rover v8.There is shit loads of stuff for them ,they are light and powerful and have been the staple of brit rodders for years.TVR are still using a bored out version.You can get about 300 bhp out of one with no problems and good reliability..............Marq
  3. suedesled
    suedesled
    Install a 300 crank and the aluminum 300 heads from 64 and you have a 268.
  4. I am building an Olds 215. Same as the Buick but it has different heads.
    They are really good motors.
    D&D Fabrications http://www.aluminumv8.com has just about everything you need.
    Lots of stuff on EBay for these motors.
    The hot ticket is a Rover block with 64 Buick 300 aluminum heads and crank. About 300 cubic inches. But you can get an easy 200 HP out of a basic 215 with cam, carb, and exhaust upgrades. Perfect for a modified.
  5. JasonK
    JasonK
    cool motors
  6. Winfab
    Winfab
    I have an Olds version of the 215 in my T roadster. Plenty zip in basically stock form, but then again with the aluminum engine the car only weighs about 1250-1300#, so about anything would seem quick.
  7. 5window
    5window
    These are really cool motors-I've got my eye out for one. You can even polish the block since it's aluminum. Here's a site for parts-
    www.egge.com
    Olds used this engine as well. Back in 1963,my dad had a factory turbo 215 in an Olds F-85 Jetfire. Most of the time it was in the shop since Olds didn't know how to keep the turbo running-but it reportedly made 215HP -first production car to give you 1HP/cubic inch. All I know is that when it was running right, the thing would scoot! ( My dad was a Navy fighter pilot and drove like one-still does at 82 for that matter.)
    Just a note-in '63,the turbo was a $300 option. When my dad traded it in on a '65,the turbo version was worth $300 less than the carb version.
  8. Empire32
    Empire32
    from FRANCE
    thanks for all your contributions.
    Another question: is it possible to adapt easily another transmition behind ? like another GM, like a th350 ?
  9. 53sled
    53sled
    from KCMO
    duntov 283 was the first to have 1 hp per cubic inch, same year hemi 345 cu made 345 hp, 56 or 57? and naturally aspirated.
  10. Empire32
    Empire32
    from FRANCE
    bttt
  11. Gasserfreak
    Gasserfreak
    from Yuma, AZ
    D&D Sells a bunch of different ones.http://www.aluminumv8.com/catalogpages/bellhousingetc.htm
    "$150.00 7176-A-10-C Adapter Plate – Bolt a late model Chevy V-8 automatic transmission to your 215 engine with this plate. "
    Drew
  12. RustikRods
    RustikRods
    im going to be using one of these in my roadster. i like them simply for the weight factor. that aluminum v8 site has alot of good info
  13. Empire32
    Empire32
    from FRANCE
  14. colorado51
    colorado51
    I think that in stock form they had about 190HP, not exactly speed demons.
    I actually put one in a Vega once.
  15. suedesled
    suedesled
    Would you believe there are 2 guys here in Oregon with one on a chainsaw?
  16. dixiedog
    dixiedog
    Now that I would like to see a picture of!!!
    Does anyone have a pic of these?
  17. colorado51
    colorado51
    HaaaHaa, Oregonians are funny :D :p . I spent some time in Eugene and almost moved there a few years ago.
    A chainsaw? 215's are a little too anemic for me, but put one in a CHAINSAW? Now that is another story! :eek:
  18. BAD ROD
    BAD ROD
  19. wannabewannabe
    wannabewannabe
  20. boothguy
    boothguy
    Great little engines. Had about 30 of' em over the years. If you're looking for one try to get one that spins, usually means it wasn't overheated and I've never seen a bad bottom end in one, cam goes first. HP ranges from 155 for stock 2bbl buick/olds and 133 for low compression Rovers on up. Stroking these is not as simple as putting in a '64 300 crank and heads, lots of expensive machine work is required. Besides being different they only weigh a little over 300lbs, are very economical and a lot of stuff is available if you know where to look. Limited torque but a great engine for a light car. D&D is the best place to start with one of these, he definately knows his stuff.
