Technical Buick bellhousing conversion
Discussion in 'Traditional Hot Rods' started by oldsmolet, Mar 8, 2020.
  1. oldsmolet
    oldsmolet
    B0A511E9-A2A3-4639-99BA-46B5B7255309.jpeg 9B3C10C1-47BC-42AC-8243-EFEA2C5B5682.jpeg I’ve had this for years and never knew what it was for. I believe I pulled it from a 42-48 Buick trunk that I robbed taillights out of probably 15 years ago. It has written on it Buick to something. Buick straight 8 to chevy maybe?
  2. mgtstumpy
    mgtstumpy
    Looks to be a Nailhead (364, 401 or 425) to manual (4sp), this is a Bendtsen's adaptor however bolt pattern for transmission is slightly different.
  3. oldsmolet
    oldsmolet
    My measurements are different than those so must not be muncie
  4. oldsmolet
    oldsmolet
    Top space is 8.25 but bottom 2 bolt holes are like 7 inches
  5. Mr48chev
    I can't find the pattern for the older Chevy transmissions (54 and earler car and 47 and earler truck) but that may adapt to that closed drive trans. Someone has to have a transmission or bellhousing handy to measure though. I had a 54 nailhead that I was going to swap into a 50 Chevy hardtop back in 1966 and couldn't manage and adapter or stick setup.
  6. 1pickup
    1pickup
    Put me as first in line, if you are selling it.
  7. oldsmolet
    oldsmolet
    Here’s the measurements. Someone’s gotta know.
  8. Ive got one similar. mine adapts to a lasalle trans.
  9. Not early chevy the center hole is too small.
  10. oldsmolet
    oldsmolet
    This is yours and mine right? Look different
  11. Nailhead A-V8
    Nailhead A-V8
    if it adapts a 322 to a Lasalle trans its the missing link in my project lol
  12. oldsmolet
    oldsmolet
    I need the measurement off a LaSalle to see
  13. Yes that's mine on the right. Man that's a old picture. That was back when I was Driving the old Red Peterbuilt. Ive also got a Offenhauser adapter that adapts a 322 to a ford flat head trans or mini bell. I don't think your bell is for a 364 or 401. I pictured a 56 Pontiac 316 bell. pontiac eng 013.JPG
  14. vtwhead
    vtwhead
    It appears to be a Lasalle with the right top ear offset and the step for the candlestick insertion. The center ****** is the 37 lasalle. However, there is no hole in the face of the bell for the shift rail that will protrude when shifting gears.
  15. oldsmolet
    oldsmolet
    I wonder if it’s for like a 6 bolt Buick
  16. Hnstray
    Hnstray
    from Quincy, IL
    That was my first thought. However, that would also require the hole for the shift rail that Walt referred to above. Your bellhousing is definitely intended to be used with the ‘candlestick’ TO bearing tube common to GM manual transmissions/bellhousing (except Chevy) from the late ‘30s thru the mid/late ‘50s.
    Ray
  17. oldsmolet
    oldsmolet
    True. The hunt continues. Lol
  18. Hnstray
    Hnstray
    from Quincy, IL
    PM sent.........
  19. oldsmolet
    oldsmolet
    It’s a trans dapt adapter. It is an HC 53-56 nailhead. Here’s a trans dapt manual on eBay that looks like it would have the answer if I could read it. Guy wants more than I’m willing to pay to find out. Anyone have one of these old manuals?
  20. vtwhead
    vtwhead
    I have a transdapt catalog. I will go locate it after dinner. Food always comes first, u know how that works.:D
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    I have a trans dapt catalog but all the 322 buick adapters are listed HC. there are more numbers after that for what trans it goes to. what are the rest of the numbers on yours??
  22. vtwhead
    vtwhead
    My catalog sheets list the HC version for 53-56 all with a foot note stating that one must use the Chevy 6 pressure plate #3772926.
    Looking further into the trans diagrams it says the bolt pattern you have shown above is the large Buick case with the 6 bolt top cover. Commonly found in 37/38 Century's. This ****** can be upgraded with a later 51-59 Olds ****** gear gut to provide a killer ****** although it is still a non synchro first. I am running one behind my Olds, @F&J has one in his 32 with an Olds and I don't recall how many @Paul has in his horde and behind his engines. F&J did a tech on the conversion. Pretty straight forward deal.
    Here is pic of one of Pauls engines with the 37 ****** attached that he had on another thread last week.
    wood remover likes this.
  23. oldsmolet
    oldsmolet
    Exactly what trans I thought it was. What HC number is that?
  24. oldsmolet
    oldsmolet
    I was just trying to match my measurements to one of the options. Mine isn’t stamped at all
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    The HC is the top row and the trans options are listed above
    5FEC7E32-F24B-45E7-BA3C-507DF2EE9723.jpeg BD710FAE-D7F1-46A6-9519-8CF24C0CD0D4.jpeg F53DB788-A929-49F4-A4EE-2626E52A1156.jpeg B0F5CBDF-AA67-4FB0-B252-BEF82DC5982A.jpeg 0D17C013-BBE9-4548-934D-80A432019F6A.jpeg BE53EB05-A171-47F3-B6BB-E46B2D5ED339.jpeg
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    are you sure? it should be cast in. have you cleaned it real well???
  27. oldsmolet
    oldsmolet
    I’ll check again. Not sure where it’s usually stamped
  28. vtwhead
    vtwhead
    sometimes in small letters on the inside but it would seem that it should follow the HC. My catalog sheets don't look anything like the above. Might be an old listing. It only shows the HC, HD,HE,HF and the HG with a couple foot notes.
  29. oldsmolet
    oldsmolet
    I don’t see anything. I didn’t even see HC just saw that row on the list and know it’s 53-56 nailhead. Makes sense I pulled it from a 42-48 Buick so they most likely had this to put a nailhead with the stock transmission. Doesn’t sound like something I’m going to have any use for anytime soon so may send it down the road to someone else.
