buick drum brakes question
Discussion in 'The Hokey Ass Message Board' started by bigblock69n, Aug 12, 2010.
  1. bigblock69n
    bigblock69n
    I have read many other post's and maybe i am missing something but here is my question. I am running buick drums and original hubs on ford spindle's I have the buick brakes also but they do not appear that hey will work. What backing plates can I get that will work has anyone else done this? The brakes I have are off a 61 buick Thanks
  2. roundvalley
    roundvalley
    Do you have the aluminum adapters backing plate to spindle?
  3. bigblock69n
    bigblock69n
    no i don't My backing plates are 3 hole units that are pretty much flat and it looks like I need some with a offset maybe
  4. roundvalley
    roundvalley
    I used '60 backing plates with adapter. No problem. Search Buick Brakes and you will be busy.
  5. budd
    budd
    i have a set of 53 to 56 F250 backing plates for mine, they bolt to the spindles and are self energising, there are threads on here about this setup.
  6. YBlockCruizer
    YBlockCruizer
    You'll need to use '59 or earlier Buick Backing Plates with an aluminum 1/2" thick spacer. You can use later finned Buick drums with this. You can see the spacer between the spindle plate and backing plate. You can use the stock Buick brakes with this setup...Steve
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The backing plates you need were used on Buicks from 1958-60. I lucked out and picked up a pair from a guy with a pile of old stock car parts at the swap meet in Thompson, CT.
