Buick Finned Drums?
Discussion in 'The Hokey Ass Message Board' started by Nick32vic, Sep 13, 2003.
  1. Automotive Stud
    Automotive Stud
    When I did mine I used napa 641-1145 studs, they fit like they are made for the conversion. I used a Rels brake lathe to cut both the drum and hub. I was using the ford 5 x 5.5 bolt pattern, so after the hub fit the drum I just used those holes as a guide in the drill press. I also bolted the hub to the drum but that was probably not required.
    http://www.jalopyjournal.com/forum/showthread.php?t=64647
  2. MiketheRat
    MiketheRat
    what about using buick drums on the rear? anyone done it?
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Yep... used the on the rear of my roadster too-
    57 olds rear with 12" 56 pontiac? ****... maybe they're olds backing plates I would have to ask eardy as I got them from him at 3am as he was going through rear ends trying to find the same mateing surface as the rear...
    they need a small spacer and thats it. I thought they were poncho cuzz it had all three- olds buick and pontiac in the mix.
    Tuck
  4. Automotive Stud
    Automotive Stud
    I want to see the ford banjo rear hub put into a set of buick drums. Now that I did the front I want to do the rear. I have more finned drums, I think I have some stock ford rear drums ('47 type)
  5. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I guess it all depends on how your building your car- I'm sticking strictly to a "snapshot in time" period 60's car. I think Buick drums look funny on an early styled car, as the Buick drums didn’t come out until the early sixties.
    Seems to me putting Buick drums on a banjo rear would be backwards- as the 57 olds rear was a far superior rear to use at the time... it was the predecessor to the ford 9" and the rear they used on the strip behind most compe***ion diggers-
    It also has the same bolt pattern as the Buick drums so you don’t have to re-drill your axle.
    Tuck
