Customs Buick finned drums
Discussion in 'The Hokey Ass Message Board' started by hot4hotrods, Aug 17, 2015.
  1. hot4hotrods
    hot4hotrods
    from U.K
    I'm thinking of putting some finned aluminium drums on my 58 Buick Special, the Special was the cheaper model made in 58 and the only one with cast iron drums as standard. Does anybody know if any of the later finned Buick drums from the 62-66 models will fit the 58?
  2. gimpyshotrods
    gimpyshotrods
    If I remember correctly, the earlier cars had ball bearings, and the later had tapered roller bearings.
    Not sure where the changeover was.
  3. Fr. Buick
    Fr. Buick
    The big thing will be to get the Roadmaster backing plates, to allow 2.5 inches of shoe and drum width. The aluminum drum should fit right onto your stock hub. You will need, however, the longer lug bolts.
    I did this on my '54 Super, and it made a very nice upgrade.
  4. Kato Kings
    Kato Kings
    from Minnesota
    The backing backing plates on your 58 are the same as the backing plates on the 58-60 with the finned drums. I think you are going to need to find drums that were on a 58-60 buicks.
    gimpyshotrods likes this.
  5. gimpyshotrods
    gimpyshotrods
    I think so, too.
  6. Rusty O'Toole
    Rusty O'Toole
    Can you still buy the aluminum drums?
  7. Kato Kings
    Kato Kings
    from Minnesota
    Good used ones are out there. I think starting in 61 the bearings changed and so did the wheel studs, lugs. 58-60 had lugs and 61 and up had studs I think.
  8. gimpyshotrods
    gimpyshotrods
    We wish.
