Technical buick nail head in a model a
Discussion in 'Traditional Hot Rods' started by richard crow, Mar 31, 2024.
  1. richard crow
    richard crow
    how does a 64 buick eng fit in a model a is it a big problem my flathead blew up & i have a1954 buick eng
    duecesteve likes this.
  2. 73RR
    73RR
  3. MojoRacing
    MojoRacing
    Here's a picture of my father's 31 roadster with a 322 nailhead. It fits pretty well.
    don colaps and Desoto291Hemi like this.
  4. jaracer
    jaracer
    The problem with the nailhead is that it is a pretty long engine. I had to move my firewall back about 4 inches for my 401. The other problem is the starter is on the left hand side of the engine. I ended up using a "Steer Clear" setup for my steering linkage. 037.JPG
  5. Illustrious Hector
    Illustrious Hector
    That's a "deep-ender" You're not telling us what transmission the car will have. Presume it has a Ford
    3 spd. ? Do you have the Buick Trans? The left hand starter is not a big deal with a recessed firewall as
    jaracer shows above, and as my '29 has. Engine mounts,Trans mount, exhaust, lots may change. How bad is the Flatty blown up? See how we're gettin' into the deep end? Send full-sized pics.
  6. Is the planned Buick engine a 64 or a 54? Different answers depending on which.
  7. patterg2003
    patterg2003
  8. richard crow
    richard crow
    the eng is a 1954 i will be using a 39 ford trans the has cross steering with a vega box
  9. 1954 engines are either a 264 or 322, which is 1" wider in the bell housing area than the later 364/401/425. As previously stated, the firewall will have to be modified to accommodate the length of the engine. Exhaust manifolds that are center dump to clear the motor mounts and starter would work best, and the best ones came off of 1961 LaSabre 364 single exhaust. Transmission adapters for that engine a little harder to find but are out there.
    Illustrious Hector likes this.
