Technical Buick Nailhead Intake Manifold
Discussion in 'Traditional Hot Rods' started by Bib Overalls, Jun 18, 2024.
  1. I am currently building a 401 Buick Nailhead for a future project. I have acquired polished aluminum valve covers, valley cover and spark plug wire covers. I have just received my long awaited aluminum four barrel intake manifold from TA Performance. My question; should I leave it raw, paint it to match the heads and block. If I paint the manifold the effect will be subdued. If I polish the manifold the if follows that I should polish the front cover and water pump. I am concerned that polishing the manifold will be too much sparkle in a traditional hot rod (32 three window highboy). I'm 81 and this is my last hot rod and I want to do it right as I don't think I will get a second chance. Would you go for the glitter or tone it down?
  2. JohnLewis
    JohnLewis
    If it's your last hod rod, do what you think will make you the happiest.
    dirt t and Budget36 like this.
  3. JohnLewis
    JohnLewis
    Aside from that I like something that stands out.
  4. Grumpy ole A
    Grumpy ole A
    As said it’s your hot rod. But if it was mine I would polish it. Just gotta have some bling.
  5. 3quarter32
    3quarter32
    Polish and clear powder coated.
  6. 40FORDPU
    40FORDPU
    I've always painted my aftermarket intake manifolds engine color....but as said "your car" make yourself proud.
  7. 1-SHOT
    1-SHOT
    from Denton
    I like the polished and clear power coat. That way you have a little bling and easy maintance
  8. rockable
    rockable
    I have had a couple powder coated silver and like the way that looks. It's much easier to keep up, as well.
    Bangingoldtin likes this.
  9. My preference depends on the application. My 401 is going in a closed hood car, so fully painted is my choice. An open hood car would have more bling. Your car, your choice. A polished manifold without a protective coating would need constant maintenance. Powder coating (whether clear or color) will keep it shiny.
  10. swifty
    swifty
    On my 401 I had all those alloy bits water bead blasted. The bloke that does it puts something in the water so that oil stains and such do not go into the alloy and can be removed with detergent and a scrubbing brush. The finish is soft, subdued and I think a bit different instead of the bling. Engine is painted satin black and the headers are ceramic coated satin black.
    Fordors likes this.
