I'm curious how much power I can get from a 401 Nailhead with 6 Stromberg 97's and headers. What other inexpensive things can I do to a 401 to get more power out of it. I'm looking for good power, somewhere in the 385 and up horsepower range. Is it possible to get 400 hp? Should I supercharge it, do they make Nailhead superchargers...although a supercharger wouldn't be cheap.... hmmmm...
Well I meant that Im definently going with the 6 97's and that is pretty much all the money I have for the motor. So I was asking what inexpensive things I can do after i put on the 97s.
Well it doesn't cost much to pocket port one, I assuke tmat you are not rebuilding it, if so you can align bore or hone one pretty cheap ( some only need a little honeing as opposed to boring and some don't need it at all) that is good to free up a little torque. Yes you can get a blower manifold for a buick, or you can make your own in a pinch. Cam shafts are not really expensive in the whole scheme of things. Upgrading the ignition always helps as well and is not a costly mod. Unless you arre a real tuner you will probably capture more zot with a single 4 then you will 6 dueces. Remember this every time you begin a build, "speed costs money how fast do you want to go?"
If you own a'32 Ford the first thing you should do is learn to spell Deuce. Ron Oh! It's going in a Duece coupe![/QUOTE]
