Buick Nailhead Question
Discussion in 'Questions & Suggestions' started by 48silverstreak, Jun 17, 2004.
  1. 48silverstreak
    48silverstreak
    I have a Buick nailhead that came out of a 57 Buick Century but its believed to not be the original engine in the car.
    I need help in finding out if its a 364 or a 401. The casting # on the heads are 1172889. Are there any other tell tale signs of which this engine might be?
    Thanks in advance for the help.
    Rob
  2. Mike Paul
    Mike Paul
    Need the casting # from in front of the valley cover to be sure which one it is.
    suffix should be like
    3F =1959 364 or
    4F =1959 401 or
    3G =1960 364 or
    4G =1960 401
  3. suedesled
    suedesled
    The 57 364 had a cast iron timing cover and all 401's had an aluminum cover. This will be a clue but 364's after 58 had aluminum covers as well but it could be quick answer for you. Good Luck
