Buick Nailhead Switch Pitch autos?
Discussion in 'The Hokey Ass Message Board' started by HotRod28AR, Apr 17, 2011.
  1. Can someone educate me on these? I'm using the original Super Turbine 400 behind my 401 Nailhead (putting this in a '57 Chevy) and was wondering if all these trans had the switch pitch option, and what exactly does it do? How is it controlled? My combo is out of a '66 Electra 225. Thanks,
    -Dean
  2. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
  3. Looks like I do have a SP400. What would be the easiest way to wire this back up to work with my swap? I still have the big switch pitch assembly that was mounted to the stock 401 intake manifold/carb, but I'm running dual quads when I put it in the '57 Chevy. Was just looking around in the archives and it looks like I can just rig up a switch on the dash to activate the SP. Wiring??? Thanks,
    -Dean
  4. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    That would be the easiest way to do it, but I have no idea how difficult would it be to modify the solenoid to work with your dual quad set up. I would examine how it was set up on a dual quad manifold on a buick and see if you could make it work.
  5. zman
    zman
    from Garner, NC
    another trick people liked to use is to hook it to the brake switch, when the brake is depressed high stall, brake off low stall....
  6. d2_willys
    d2_willys
    from Kansas
    If you could mount two switches, one for idle, one for wot, then you could use the wot switch for kickdown and for hi-stall. You would want to wire a diode between the kickdown switch and the idle switch to avoid having the kickdown set off by idle switch. This would get you close to what the original setup did. (Cathode of diode goes to the idle switch terminal which goes to the torque converter switch pitch terminal on trans. Anode side of diode goes to kickdown switch and then to the kickdown terminal on trans. The other terminals on both switches are ignition +12V.)
    Or you can play around with a switch on the dash for the switch pitch.
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I have a dual quad 401 and SP400 in my '50 Chevy sedan delivery. I have the original kickdown switch on the accelerator linkage that has the switch built in to switch the pitch at WOT. I also hooked up a pushbutton switch and mounted it in the empty hole in the floor where the clutch pedal used to be. That way I can switch it at any speed.
    Switch is visible in this pic
