Hot Rods Buick ~>olds olds ~>Buick!! Help!
Discussion in 'The Hokey Ass Message Board' started by LiveActionMotorsports, Jan 4, 2016.
  1. ImageUploadedByH.A.M.B.1451956403.138230.jpg . I picked up this 52 olds axle for my 52 Buick today to use to convert to open drive but u got it home and it's 3.5" wider I'm guessing it's from the bigger bodied olds does anybody know if I can just swap the olds 3rd member into my Buick axle? Thanks!
  2. Hnstray
    Hnstray
    from Quincy, IL
    I don't know the answer to your question, though some research will determine that. However, what are your plans for controlling the axle ***embly AFTER the torque tube is gone? You may already be aware, but those diagonal braces currently on the Buick are not
    sufficient for that purpose.
    Either a GM "truck arm" setup or a 4 bar system are the most common for that purpose.
    Always glad to see another Buick in build. Best wishes with your project.
    Ray
  3. Thanks! Here is my build thread! 1952 Buick "Pearl" a factory custom. My first chop http://www.jalopyjournal.com/forum/...earl"-a-factory-custom.-My-first-chop.967980/
    I'm going to 4 link the rear not sure if I'm going air ride yet or not.
