Hot Rods Buick People-Help Please!
Discussion in 'The Hokey Ass Message Board' started by michaelvz51, Nov 27, 2023.
  1. michaelvz51
    michaelvz51
    from So Cal
    Hello Hambers, My good friend and I are working on a 1933 Buick Series 57 and are having a tough time understanding how to remove the Opera Vent Window Regulator Handle. I have attached a picture of the Handle in hopes that the Buick spe******ts can help with this. We need to remove this handle for upholstery, but it is on the shaft solid and won't budge. We don't want to apply any more force as it may break and these are pot metal to begin with. Any help and guidance is always appreciated. It seems like there may be some type of spring behind it or something that is holding it in place but this is a guess.. Buick Handle-Craig G.jpg
  2. Fortunateson
    Fortunateson
    Can the shaft be removed from the mechanism with the handle still attached?
  3. Torana68
    Torana68
    from Australia
    if you push the escutcheon down you will see how, there is a clip or something?
  4. hotrodjack33
    hotrodjack33
    That would be my guess as well. The escutcheon is hiding a clip, pin or screw.
  5. michaelvz51
    michaelvz51
    from So Cal
    This may be the answer, we will look at it from that perspective.
  6. michaelvz51
    michaelvz51
    from So Cal
    Hello, no clips, screws or roll pins that we can find
  7. michaelvz51
    michaelvz51
    from So Cal
    No clips, roll pins or screws that we can see so far
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. '29 Gizmo
    '29 Gizmo
    from UK
    Just fitted one to the wind up rear window on a 34 chev coupe. There is a "C" spring clip that you can only see if you push the escutcheon back for clearance. Its just behind the head of the handle. If you cant push it back to see behind it you are screwed. The clip can be installed blind as its a spring clip but to get off you need a gap.
  10. BJR
    BJR
    As bad as that pot metal looks even if you get the pin or clip out I will bet that it is going to be stuck to the shaft big time. There is either a clip as said or a small pin holding it on but you have to pull back the escutcheon to see it. That old pot metal swells with age, even NOS parts still in the box go bad. That's why they call it pot metal, they threw anything that could find in the pot to make it.
  11. michaelvz51
    michaelvz51
    from So Cal
  12. michaelvz51
    michaelvz51
    from So Cal
    Thank you 29’ we will look for the clip now
  13. michaelvz51
    michaelvz51
    from So Cal
    Thank you BJR, this is good info
  14. SS327
    SS327
    Johnny Gee got it!
