Technical Buick Straight 8 angle
Discussion in 'The Hokey Ass Message Board' started by Rj27buick, Jun 29, 2024.
  1. Rj27buick
    Rj27buick
    Looking for feedback
    I mocked up a wooden cradle for a 49 Buick straight 8 to be able to get measurements for frame height. To get carb level the engine is at a pretty large angle. Does this look correct? The intake is definitely molded at that same angle.
    Is this angle required for oil flow?
    Does this angle look correct?
    thanks in advance for your feedback.
    DF6C1CDF-CF81-4E1F-92EA-B140414D5280.jpeg 7BE96D55-228A-47F9-8DE0-594F6A35DEC4.jpeg
  2. It appears you are using the earlier front engine mount and the mounts 1947 up. I will consult my service manual.
  3. gimpyshotrods
    gimpyshotrods
    The angle is to reduce the size of the transmission tunnel.
  4. Rj27buick
    Rj27buick
    Yes I have the later engine mounts may or may not use them once I get height requirements for frame. I set the level based on carb.
  5. The carb should be fairly level after the install and oiling will not be affected by the angle as it has a floating pickup on the oil pump. Your angle in the picture looks about right. As Gimpy indicated, the angle was created to reduce the size of the transmission tunnel front opening for additional floorboard room and to have a fairly straight angle to the rear axle. Since you are converting to an open driveline, that is not as critical.
  6. Rj27buick
    Rj27buick
    Thanks for the feedback - I appreciate it
  7. The later side engine mounts came into play to reduce the amount of "rocking" the engine did with the front mount. Depending on the car there could be steering box interference issues.
    Edit: The earlier engines used a 4-point mounting system- two mounts on the front cradle, and two mounts at the bellhousing. Since you are using an adapter and later transmission, the bell mounts are gone. I would use the later style side mounts because of this.
  8. Dave G in Gansevoort
    from Upstate NY
    Just an observation. At the angle it's sitting at, the oil filter canister appears to be straight up and down. Kind of like that's another indication that you nailed the angle...
  9. The angle occurred in 1938, I believe, when rear end type was changed. May have had to do with driveline angle.
    Engine will not care.
    Ben
  10. Rj27buick
    Rj27buick
    Thanks everyone
