buick straight 8 split manifold???
Discussion in 'The Hokey Ass Message Board' started by Kustom7777, Apr 30, 2005.
  1. Kustom7777
    Kustom7777
    from Austin, TX
    im buying a 53 buick with a straight 8 and would love to put a pair of smittys on her,,,i know nothing about straight 8s, and was wondering if there is a split manifold or headers available for this, or do i need to go the homemade route?..anyone ever split their own manifold,,,how'd you do it????
  2. sonnyb
    sonnyb
    from n.c.
    headers are going to be scarce....if you,re not going to build a tire smoker, the split manifold will be ok. go to the junk yard and find a suitable flange, use a hole saw to cut a hole in your manifold and weld the flange on using cast iron rods. determine where you want it split and cut a gap almost through the manifold and weld in a divider plate.[about 1/4 thick] the coolest buick i ever heard was split 5 and 3....killer sound.:)
  3. fatassbuick
    fatassbuick
    from Kentucky
    Buy an 2x2 Edmunds intake and build a header. It's not that difficult to make the flanges, very basic layout.
  4. Jdee
    Jdee
  5. draggin'GTO
    draggin'GTO
  6. Green Goblin
    Green Goblin
  7. Kinky6
    Kinky6
  8. Scotch
    Scotch
    The 320ci Roadmaster stuff will not fit on the smaller 248/263 stuff. It's like big block/small block S-8s and not too many parts will swap over.
    Scotch~!
  9. InjectorTim
    InjectorTim
    For my 53 I have a Dual intake manifold from a 41 and a pair of split exhause manifolds. They were stock equipment of buicks for a long time pre-WWII.
