Buick Straight Eight Plug Wires - do they make 'em?
Discussion in 'The Hokey Ass Message Board' started by Ricky Rocket, Aug 10, 2011.
  1. Ricky Rocket
    Ricky Rocket
    Hello, new to the forums. I have a 49 Buick with an inline 8 engine and can't seem to find a place to buy a set of 8 wires. I can get plenty of straight 6 cylinder sets, but the V8 wires are way off on the sizing (too long and/or too short). Any ideas? Thanks in advance.........Rick
  2. xsquiden
    xsquiden
    First thing do an intro. Buy a universal set for a v-8 parts stores have them.
    later mike
  3. rodl
    rodl
    Hey Rick
    Welcome to the HAMB. Go to a spe******t -hot rod/speed shop/spare parts or auto electricians place. You should be able to buy a length of cable(measure up your total length) and the terminals. You may also need a crimp tool for the terminals. While you're at it, think about how the leads will look when installed and grab yourself a spacer bracket to make the leads look neat,and not hang on the exhaust headers!!
    RodL
  4. mrpowderkeg
    mrpowderkeg
    Make them. Making and repairing plug wires is pretty simple stuff.
  5. Ricky Rocket
    Ricky Rocket
    Thanks guys, the engine has a tin cover that holds the wires in place and acts a splash shield, so I don't think I'll need looms. I used to make wires and have problems with the ends always coming loose (poor quality I suppose). I'm still up in the air over solid or suppression wires. My 1949 AM radio doesn't work, but I'd like to get it going some day and stick an old school FM converter on it. Right now I drive around using my iPod and a set of headphones.....doesn't really cut it for the p***engers though! LOL
  6. Sinister Sleds
    Sinister Sleds
    from Gloucester
    AC Delco also used to sell wire by the length and you cut it to fit as you needed (100ft rolls) and you either re-used or bought the ends. I think I have a roll around here some place but can not put my hands on it right now. If you get in a bind send a PM and I will find the roll and send you what you need.
  7. RichFox
    RichFox
    I use Packard 440. I solder the ends. You might be able to find Rajah clips for the plug end and be very cool and period correct. The Buick came with solid wire. I would stick with it.
  8. goose-em
    goose-em
    from Louisiana
    check out thehotrodcompany.com. They sale plug wires, rajah ends, etc. Make them yourself is the only way to go IMHO.
  9. RichFox
    RichFox
    goose-em is right. This is Hot Roding. Not Power shopping. We all buy lots of stuff for our cars. But some of it is just easier to make than to track down and pay to much.
  10. nali
    nali
    I needed solid wire for a 1947 outboard engine , and my noname local autopart could have wire and terminals for cheap .
    Build you own .
  11. oldpl8s
    oldpl8s
  12. captainjunk#2
    captainjunk#2
    had to book mark bobs automobilia hadnt heard of this store before , might come in handy
  13. terryble
    terryble
    from canada
    You really have no idea what a straight eight Buick motor looks like do you? The advise is good but the reasoning is flawed.
  14. 32SEDAN
    32SEDAN
    X2 best to make your own. As mentioned above, you can also get the fabric covered plug wires in different colors.
  15. zman
    zman
    from Garner, NC
    bingo! :mad:
    yep :D
    Sounds more like operator error than poor quality... :eek: I've been making wires for years and have had no problems.
  16. damagedduck
    damagedduck
    from Greeley Co
    try local mom & pops motor cycle shops,i bought some at a small indi shop.by the foot [$1-ft] W/ boots & clamps.
  17. motion guru
    motion guru
    from yacolt, wa
    call em up and tell them what motor you have and they will sell you a set or sell you the parts to make your own set. I have had great support from these guys . . .
    http://www.magnecor.com/magnecor1/main.htm
  18. RichFox
    RichFox
    OK. What did I muss that was flawed in his reasoning. Buy enough wire to make your set. Make your set. Maybe use some looms to make your set neater. I believe the OP wanted to use the OEM plug wire cover, so the plastic things are unnecessary. Where is the reasoning flawed, if you don't mind showing me.
  19. zman
    zman
    from Garner, NC
    I think it just has to do with the exhaust remark, since the exhaust is on the other side with the intake. All the "enough wire and connectors" is sound though as you said...
  20. the trick to custom sets is the right spark plug boot and the right dist. ends ... so two four cyl sets or six may work just fine
    geez a couple extra wires is ok
    you do not need a high performance wire set or the new carbon core ... but they will work
    surprisingly you should be able to find a ready made set thru a major parts store napa .. auto zone they just will not have it on the shelf
    take one off at a time and match the length or make a new one ... remember the firing order its on that cover and dist spin direction
    I had two wires switched on my 52 buick for 6 years ran okay but when corrected it was really quite peppy
    always twist plug boots a little first before pulling them off... also check that fragile hot lead coming into the dist as its likely gonna break
    good luck and post some pics
  21. RichFox
    RichFox
    OK. That makes sense. Thanks. RF
  22. nali
    nali
    No offense to rodl , but this is really funny :)
    Nice . I must admit I didn t search yet . Are they easy to find , or obscure specific dealers ?
    I love yellow wires , but they may be OT on a stock straight 8 ...
