Projects Buick Virgin
Discussion in 'The Hokey Ass Message Board' started by nerey69, Feb 6, 2011.
  1. nerey69
    nerey69
    from Hemet
    Just got my hands on a 55 buick special with a 322 nailhead (I think) need help starting it It sounds like the firing order is off fire coming out of the carb I set the wires at 12785463 and all possible order on the cap same diffrence what am I doing wrong?:confused:
  2. brigrat
    brigrat
    from Wa.St.
    12784563 right hand rotation
  3. ratfink56
    ratfink56
    But here it is in a nut shell F.O. 1 2 7 8 4 5 6 3 :smash: Engine left bank(drivers side)2,4,6,8 right bank 1,3,5,7 Dist rotation clockwise looking down from the top of engine. Hope this helps you out. You can also locate the firing order on the intake manifold:thumbsup:
    stolen from Team Buick website-hope it helps
  4. nerey69
    nerey69
    from Hemet
    Thanks tried all that thinking timing chain is off does any one have a pic of how the timing chain lines up?
  5. brigrat
    brigrat
    from Wa.St.
    The firing order you posted does not match our's , you did see that didn't you?
  6. nerey69
    nerey69
    from Hemet
    no thanks let' see what happens
  7. nerey69
    nerey69
    from Hemet
    Changed them over still same diffrence
  8. raengines
    raengines
    from pa.
    sounds like an intake valve might be sticking open to me, remember the car might have been parked for this reason. could have a lobe off the cam too.
  9. nerey69
    nerey69
    from Hemet
    yea that sounds like a possibility
  10. Just because you have the wires in the correct order does not mean you're out of the woods. Did you find TDC on the #1 cylinder (on compression) and line up the rotor with the #1 plug wire?
  11. nerey69
    nerey69
    from Hemet
    yes sir I did
  12. pug man
    pug man
    from louisiana
    Open up the throat of the carb and pour a little transmission fluid and spin it over. It might help loosen up the valves if they are stuck.
  13. brigrat
    brigrat
    from Wa.St.
    It's time for a compression test, if it is a valve it will isolate which one or ones...............................................
  14. BadassBadger
    BadassBadger
    from wisconsin
    use lots of either! :)
  15. Century
    Century
    Congrats, post some pics!
  16. Then there is another problem. Could be anything from a thrown rod to who knows what. If you have a sticky valve or two, it should still fire, although it will run ****py. The compression check should be the first thing you do. It will tell you a lot. Don't dump a bunch of "either" down the carb. It won't cure anything. Take it one step at a time. If you have decent compression, spark at the right time, and fuel it should light up
  17. drw47
    drw47
    If you are running your spark plug wires thru the cover on the side of the head/engine, there is a factory spec on their placement, like a braid, that will keep them from misfiring. Just a thought.
  18. Gman0046
    Gman0046
    55 Specials came with 264's not 322's. Check your engine serial number.
  19. nerey69
    nerey69
    from Hemet
    Ok guy's here's the skinny I just removed my valve covers and discovered that my push rods are bent to hell. What in the world would cause this. From what I have learned these are not intrusive valves so what the *!@# only one valve is sticking the number 6 intake but 8 push rods were bent bad.
  20. nerey69
    nerey69
    from Hemet
    Would mechanical timing do this? Or does anyone know if the push rods are all the same or ar their diffrent sizes for intake and exhaust?
  21. nerey69
    nerey69
    from Hemet
    My next thing is to rip off the timing cover. can anyone tell me what the gears should be set to up down towards each other or what?
  22. r8odecay
    r8odecay
    Wait, so earlier in the thread you said the timing chain was off, so...you put it back on without verifying the cam timing marks?
  23. tb33anda3rd
    tb33anda3rd
  24. truckncoupe
    truckncoupe
    Once again, this forum is a wealth of knowledge,,,great job guys!:D
  25. nerey69
    nerey69
    from Hemet
    Have not taken off timing chain yet need to know what it needs to be set at so i can check it
  26. raengines
    raengines
    from pa.
    you probably have 2 valves stuck closed along with the one stuck open, too many reasons to list why a valve job is your best option now
  27. 58fed
    58fed
    The easiest way to tell a 322 from a 264 from a visual, the 322 will have a harmonic balancer and the 264 doesn't.
  28. nerey69
    nerey69
    from Hemet
    Thanks guy's I think it's time to yank it and rebuild it.
  29. raengines
    raengines
    from pa.
    excellent choice
  30. espo35
    espo35
    from california
    Yep.
