Build A gas tank
Discussion in 'The Hokey Ass Message Board' started by dirt t, Feb 18, 2010.
  1. dirt t
    dirt t
    I am building A gas tank I'v read the adds for tanks in the mags and code is a supply tube from the top of the tank. who supplys a weld in bung with adjustable tube for supply? How far from the bottom of the tank is the tube? Thank you for any input
    dirt t
  2. Don't know if it helps, but there is a "How to Build a Hot Rod" book by Parks that has a chapter on tank construction. I would suggest keeping the pickup ube at least 3/4 to 1" above the bottom.
  3. HotRod31
    HotRod31
    I weld a 3/8 steel fuel line (Autozone) to an # 6 or 8 male AN weld fitting, drop it in the tank (1/4 to 1/2 off the bottom) then weld the fitting.
    Later, Mark
  4. r.s.s.
    r.s.s.
    from Alberta
    I got all the "bits" to Build my tank from TANKS Inc.
  5. dirt t
    dirt t
    I have the book,I am looking for som parts. I built
