Customs Building a '56 Olds Custom
Discussion in 'The Hokey Ass Message Board' started by 2Hep, Oct 21, 2009.
  1. 56LOWRIDER
    56LOWRIDER
    from Apollo, Pa
    I was wondering why the front gl*** is going to be easy, its seriously curved
  2. 2Hep
    2Hep
    Well easy if you have a sandblaster with a nice tight small tip. The front gl*** is safety gl***, it's new, just ordered and out of a box.
    What I did was lay fibergl*** over the windshield and the back gl***, made a template...(well covered the gl*** with masking tape first, then a healthy coat of Johnson's floor wax for bowling alley lanes, then I laid the fibergl*** over that, after a few layers, I had a template. Now cause I laid on the outside of gl*** I needed to make up the thickness of the gl*** on the inside, I used layers of cardboard and resin. This is what I've cut down to fit in my opening.
    ***side note another to chop a top with curved gl*** is to cut the gl*** first then match the roof to the gl***
    When my templet was fit into the rubber gasket (which I had to remove some length out of...I'll end up fitting the gasket in with silicone so split shouldn't matter and it is at the center bottom of the windshield) I traced butcher's paper over my template and had a pattern from that, which then was traced on my gl***.
    Everything not being removed gl*** wise was covered with sandblasting tape, (duct tape, extra thick and cardboard) to protect the gl***.
    When blasting, small tight tip. trace the line and keep removing material. until you get to the plastic (safety part of the gl***) then turn the windshield over and follow it on the other side until the top part being removed is hanging by the plastic.
    Then you need a razor blade, I heated mine up as if I were cutting ABS plastic (like a bedliner) and trimmed away.
    The gl*** edge is smooth from blasting, and I moved fast enough to avoid heating it o explode, yet slow enough to penetrate the gl***.
    On this windshield I had to remove roughly 4" off the top and some down the sides and follow the curve as the sides got skinny.
    It took a few months of research and another few months of asking questions and double checking what to do if this doesn't work. Then a few weeks of ****ing up the balls to do it, but I wanted to do it myself....and learn.
    As for the backgl***, that's tempered, and you can't mess with it. It's looking like my template for that will be used for Lexan (aviation gl***) and will be a custom made piece, but they can do it and located near Flint, MI.
    I'll post some pictures of this when I get to it
  3. 2Hep
    2Hep
    Not that it was "easy", it took time and trial and error to get it, but that's everyone's hang up with a car with a curved windshield, is what do I do with the gl***. The front can be cut, the back can't...but there's option for the back one, I choose Lexan. Some chose other types like Acrylic (MoonGlow used acrylic in the first build and the second, infact he did that in his mom's oven) use a different back window, etc.
    Another good question will be what did 2Hep do about the side vent windows?
    Stay tuned...
  4. 2Hep
    2Hep
    Mark, right now I'm trying to figure these stupid air scoops out. I started making little fins (like on a '64 Olds) to follow the lines of the chrome mohawk on the "98" taillights down the rear quarters, and I'm applying primer to the firewall.
    What car you thinking? It took me many weeks of deciding if I should do it or not, but my boss pushed me when he said I didn't have the balls to cut the roof-Brian
  5. 2Hep
    2Hep
    Here's some extra shots...
    Really my Corvette Grill that s now in my Olds grill. The Vette grill is an extended grill, made from 2 '57 Vette Grills I picked up cheap at a swap meet and teeth at various different meets... anyway lined the two bars up to get the right plan view to follow the curves of the bumper. Then I split it and welded it together under the center tooth.
  6. 2Hep
    2Hep
    Vette Grill....
    I used the center tooth from the stock grill opening to make a templet to make a bracket to house the vette grill making it a floating grill. That will be painted black
  7. belair
    belair
    That scoop idea is neat-hope it come off like you want. I really like the front end on those cars-reminds me of an F-86 Sabre. Looks like it would **** up pedestrians.
  8. 2Hep
    2Hep
    Pedestrians beware!
    The scoops still some working out to get them to where I want them, but hopefully it will be cool. Thanks!
  9. James D
    James D
    Like the grille treatment a lot.
  10. Wicked50
    Wicked50
    This is going to be one sweet ride.
  11. Ian Berky
    Ian Berky
    I 2nd that!! Great work!!
  12. Chuck Carman
    Chuck Carman
    That's badd***. Is it Buick powered?
  13. outlawsteel
    outlawsteel
    gonna be sweet most definetly gonna watch this one
  14. Albie
    Albie
    Love Vette grills. Nice concoction you got going on there. Any pics of the template?
  15. 2Hep
    2Hep
    More pics to come, as of now everything is sitting on my desktop... The engine is Rocket 324, Trans is a '55 Hydra. The trans I had rebuilt and beefed up as much as it could, Kevlar bands etc. The engine I'm waiting for the heads to be finished but for the most part is ***embled. Pict of everything on the way!
    Thanks for all the encouragement!
  16. Strange Agent
    Strange Agent
    Bring on the pics. This is a really cool project. I'll be following this one.
  17. 2Hep
    2Hep
    So much to do so little time to do it all...
    Well, playing around with scoops and subtle fins, The shot of the fin is more upright to follow the flow of the rear alittle more.
    Exhaust, I'm building scavenger pipes, all individual so six of 'em shooting out for the underside of this beast.
    and the firewall is ready for final coat of primer before shooting it with paint.
    Welded, smoothed, filled, and sanded ever piece of metal on that firewall (heater/vent boxes..etc)
  18. 56LOWRIDER
    56LOWRIDER
    from Apollo, Pa
    Thanks for the info on the windshield, Ive done it several times that way on Pickup trucks mostly. but I really like the way you made a template out of fibergl***. You really going to have a sweet ride when your done, I like the wide whites and disc caps.
  19. 322ski
    322ski
    from Ventura
    Hey hillbilly when are you going to have this beauty of motivation on the road?
  20. Pinstriper40
    Pinstriper40
    This will be sweet. Good luck with gl***- that's the part of the build I'd be scared about.
  21. 56oldsDarrin
    56oldsDarrin
    Great pictures I'm hooked
  22. Rocky
    Rocky
    Classified Editor
    I'd like to talk to you about the trans work..sending you a PM if you don't mind..
  23. 56Chevy4Dr
    56Chevy4Dr
    from Texas
    Why not just omit & discard the crank "Wing" vent windows? Since the doors uses straight/flat gl***, recut new door gl*** so that it is 4" wider. When you crank up your window, it is one big wide gl***.<?
    With a '56 Hard-Top like yours, with both front & back windows rolled down, what do think about the clean look of no "posts"? Food for thought.<o:p></o:p>
    <o:p></o:p>
    Also, could you use the '56 windshield on the back, instead of the back tempered gl***. Both gl***es are curved and close to the same width. I was wondering, if your fibergl*** template of the back gl*** was laid on a front windshield, would you be able to mark out & sandblast a new back gl*** out of it?
    I have a '56 Chevy & I am curious on your findings!<o:p></o:p>
    <o:p></o:p>
    Thanks,<o:p></o:p>
    56Chevy4Dr <o:p></o:p>
  24. 56Chevy4Dr
    56Chevy4Dr
    from Texas
    Great project!!!!!!
    <O:p></O:p>
    I was wondering if you could lay the back deck-lid gl*** at a slightly different, maybe sharper angle and just fab new metal around the original uncut tempered back gl***?<O:p></O:p>
    <O:p></O:p>
    Also, could you use the '56 windshield on the back, instead of the back tempered gl***. Both gl***es are curved and close to the same width. What if, your fibergl*** template of the back gl*** was laid on a front windshield, would you be able to mark out & sandblast a new back gl*** out of the original front gl***? <O:p></O:p>
    <O:p></O:p>
    I am perplexed with similar decisions on my '56 Chevy and look forward to your thoughts & future pictures! <O:p></O:p>
    <O:p></O:p>
    Thanks,<O:p></O:p>
    56Chevy4Dr<O:p></O:p>
  25. 2Hep
    2Hep
  26. 2Hep
    2Hep
    56Chevy-
    at least your posts on the forward part of car will be a bit more easy then the Olds/Buick as the Chevy/Ponchos are more upright and do not pinch as much.
    Hope this post will be an aide of trial and error
  27. satan's childs
    satan's childs
    here one of my 56 olds kustom that got stolen from me
  28. 56LOWRIDER
    56LOWRIDER
    from Apollo, Pa
    56 olds custom, Did you lay the windshield back or leave the front posts slanted, its hard to see in the photo
  29. 2Hep
    2Hep
    I left the pillars slanted forward. I'll try and get a better side veiw shot
  30. LarzBahrs
    LarzBahrs
    from Sacramento
    Gorgeous car, best of luck to you in your build!
