building a comet straight axle car
Discussion in 'The Hokey Ass Message Board' started by 65 comet, Aug 31, 2011.
  1. 65 comet
    65 comet
    from ohio
    IM building a 65 comet 2 door sedan with a speedway straight axle. My question is when I put the rearend under it, to get it leveled out should i just use longer shackles or sit the housing under the springs? I have heard of both was but not sure which is the best or correct way. Thanks for the info.
  2. Royalshifter
    Royalshifter
    Moderator
    I would say leveling the car would be the wrong thing to do....nose up is what you need.....so rearend on the top of the leafs.
  3. ClearSpot
    ClearSpot
    from Michigan
  4. 65 comet
    65 comet
    from ohio
    ClearSpot, I check it out everday its an awsome thread. love all the pictures.
  5. 296 V8
    296 V8
    from Nor~Cal
    What he said ^^^
    My 65 sed. Will sit stock in the back and up a bit in the front w a drilled Willys axle.
    I think they look more down to business like that
  6. 65COMET
    65COMET
    I say it is your car,build it the way YOU like it!!!!Too high in the front,to me,looks wrong.Dale[teddisnoke]Snoke's 64 sits right,Scrap Iron's Whissler 65 sat to high in the front.That is just my opinion! ROY.
  7. dv8
    dv8
    A set of Mopar Super Stock springs in the back would lift the back of the car a little, and still maintain, and probably add, the proper traction. I've seen them used on non Chrysler cars. There is a left and a right part number.
  8. choke
    choke
    Here's a Speedway kit installed. Yes the motor and tranny are in it. It's a running vehicle. You can see how high it sits. You can raise the rear by using longer shackles, but don't forget to install longer rear shocks.If you use a taller rear tire 28"-30" this helps alot. To get the look you'll only have to raise the car 3"
  9. wayne421
    wayne421
    dont raise the rear keep the nose up
  10. teddisnoke
    teddisnoke
    from So Cal
    This is a stance you can achieve with a combination of both Speedway, and stock econoline parts:
  11. teddisnoke
    teddisnoke
    from So Cal
    Someone here also mentioned the use of Chysler rear springs. I also use this style with the Hemi units, both right hand side part numbers. But know this. They will sag, to the tune of almost three inches, over time, and with race related use. These new MOPAR units are made in Mexico, and for some reason, the steel loses its arch quickly. I'm working with Calvert Racing to come up with a Split-Trac spring with the Chrysler configuration to remedy the height loss.
  12. teddisnoke
    teddisnoke
    from So Cal
    Geez, this is an old thread..... So much for that..... Ooops...
