Building a comfortable hot rod for tall people
Discussion in 'The Hokey Ass Message Board' started by HotRodRyan, Jun 24, 2008.
  1. Next year I'm going to start my 1st hot rod buildup and in the meantime I have been collecting parts for it. My dad has two bodies; a 30 ford model a 5-window coupe and a 33-34 ford 5-window coupe.
    I'm still up in the air as to which one I'm going to build but in the last month, my brother has aligned (he's an alignment tech) two different '32 ford coupes and he told me they were very uncomfortable to drive. He is 6'4" and I am 6' 3". He told me that both cars had a tilt column and with the wheel all the way up, his knee would touch the steering wheel.
    I would really like to build the model A but it looks like the 33-34 has more interior room. Whichever car I build will probably have the top chopped and maybe channeled.
    So what are some tips and tricks to building a rod for us tall people that will be comfortable to drive?
    dana barlow likes this.
  2. photofink
    photofink
    Dont chop em
    alanp561 and dana barlow like this.
  3. t-town-track-t
    t-town-track-t
    from Tulsa
    don't channel them
    alanp561 likes this.
  4. AntiBling
    AntiBling
    If I was ever going to build an A, it would have to be a sedan. I'm 6'4" and I'd have to be able to sit back enough that I can stretch my legs out to ever drive the car on long trips, and I wouldn't build a car I couldn't take on long trips. My knee would start killing me in anything I couldn't stretch my leg out in.
    Hombre, Markmonty and dana barlow like this.
  5. remove the package tray in the 34 coupe body and move the seat back. i built a `33 3-window for a guy 6' 4" that way and he is very comfortable. i'm 6 foot even and had to move the glide seat forward to drive it
  6. Shifty Shifterton
    Shifty Shifterton
    Don't build a ford. Pick a larger luxury brand like a buick or chrysler and shorten the body to hotrod proportions. Because of the extra width you can sneak some length in tub without looking out of whack, same with roof height.
    tb33anda3rd and Frankie47 like this.
  7. Trade for a sedan.
  8. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Restore em! :D
  9. fab32
    fab32
    For maintaining room for a tall person you don't want to chop OR channel any Ford before 1935 and you just f**k them up if you do it to a post '35. If low is your thing work with the suspension and stance but don't compromise an already small interior. If you've got to brag about modifying the car tell everyone you chopped it 1/8" and channeled if a 1/4".:eek::rolleyes::cool::D
    That should keep them busy with a tape measure (or a micrometer) for awhile.:)
    Frank
    alanp561 and Leakie like this.
  10. Unkl Ian
    Unkl Ian
    Three problems for us tall folk: Head room,leg room,elbow room.
    Henry must have been a short ass.
    Short of pushing the fire wall forward,you are kinda stuck.
    There is enough room in the front of the Super Bell Coupe,to push
    the V6 forward several inches,to get more leg room.A milder chop
    would help on the head room,laying the windshield back helps vision.
    Design the frame so your ass sits down between the rails.
  11. SaltCityCustoms
    SaltCityCustoms
    Heavy chop, heavy channel, sit on the roof.
    1927graham likes this.
  12. RodStRace
    RodStRace
    I'd suggest going to a bunch of used car lots and sitting in a bunch of cars. Measure the ones that work. How much from butt to roof, butt to pedals, butt to floor, shoulder to wheel, etc. If you are building a box, figure out how much room you need...
  13. junkyardroad
    junkyardroad
    from Colorado
    These guys are right, no chop, no channel, remove the package tray, and sit very close to the floor. Also, don't sacrifice suspension travel for "the look", or your head will hit the roof every time there is a bump. But you're only 6'3", I think you'll be fine in either car. Tall guys driving a sedan from the back seat look kinda stupid. (like me)
  14. hotrod40coupe
    hotrod40coupe
    Stretch the cab and the door. Easy on the chop.
  15. fiftyv8
    fiftyv8
    from CO & WA
    Dont chop, channel or recess the fire wall and you have half a chance.
    Stick with a coupe and remove the parcel tray or else use a tudor.
    They traditionally seem to be the best solutions for tall guys.
    I am 6 foot tall with a 29 tudor and it is ok but I should have left the fire wall alone and it would have been perfect. I kept the rear seat space which was needed for family.
    Basically with the tudor you can go as far back as you need and if there is still space left well you can take passengers in the rear.
    Going back too much can also cause you a vertical sight problem for tall guys to keep that in mind and also go easy on the rake.
    The further your head is from the windshield the smaller the view angle out.
    Similarly if you have this problem and have a big rake the windshield tilts from vertical to on a slope and again deminishes your height to see thru and what part you can see is all down and no up, it is surprising how much the up area helps at traffic lights and viewing ahead especially when driving down hill it can be hard to see very far ahead, not good on the highway or where there is a lot traffic around.
    As for elbow room the further into the 30"s you get seem the interiors get a touch wider.
    Good luck.
  16. Thanks for all the help guys, I think I will build the 33-34 coupe. More interior room and the body is in much better condition. Plus I think it will look ok with an unchopped top. I don't care for fenderless model a coupes with unchopped tops.
    Here's the 33 body:
    chriseakin and exterminator like this.
  17. Mat Thrasher
    Mat Thrasher
    I have a 34 Olds coupe. It has a ton of room inside with a 4 inch chop and 3 inch channel. I'm 6' tall and will have to push the seat foward. BTW I wish I had your problem which to pick an A or a 34.
    Mat
  18. Toast
    Toast
    from Jenks, OK
    I am 6'3" and I had a 28 Oakland coupe, lotsa room. The doors are 3' long. It was channeled and had a custom chopped roof, other than takin a little too much off the top it was fine. My knees were barely bent.
  19. rockabillyjoe
    rockabillyjoe
    from Seattle
    Tall? Try being 6'8" ! Every time people see me driving anything, it looks like something Roth has drawn!
    rulamar and clem like this.
  20. Clark
    Clark
    Well...room or no room the 33 is the cooler car. Just my opinion.
    Just about any car can be built for a tall guy. I'm 6 foot and had to move the seat forward 2 notches to be comfortable in my model A sport coupe. Legs are stretched out. Car is chopped and still plenty of headroom.
    Now I don't think you could channel a Model A and still be comfortable.
    It just takes careful planning. mock it up!!! Sit in it! Make funny noises if you have to. The mock ups help you figure seat placement, steering and pedals.
    999 is a fairly small car. 4T64dr is a big guy...6'3 or taller. He was suprised he fit. The floor is sunk down in the frame on that car.
    Clark
  21. Gigantor
    Gigantor
    Hey Shorty - I'm 6'10" and would KILL to be in a Model A coupe. Considering some of the cars I drive every day, I'm pretty damned sure I could make myself fit. Sure, it might not be chopped or channeled, but with one of those little chain steering wheels, I would suffer gladly.
    This Friday I'm going to pick up a 28 or 29 Essex coupe. Those are a little bigger than a Model A in all dimensions, and while not as cool in my mind as a Model A, I got a few ideas that will make it all the better a ride for a big bastard like me.
    Good luck, and if you need to get rid of that pesky Model A coupe body, let me know.:cool:
  22. Tbomb428
    Tbomb428
    from SoCal
    It looks like you've already made up your mind, but for what it's worth I'm 6'3" and I've also got an 'A' Tudor Sedan and fit comfortably. The guy who built it is 6'5" and mounted the seat further back for legroom.
  23. PoPo
    PoPo
    just sell them to me.. im shorter than you.. lol jk
    where are you from in Il? im right on the border
  24. VNCduke
    VNCduke
    from Washougal
    Heres an idea...build a roadster
    clem likes this.
  25. I live right by O'Hare intl. airport
  26. billbrown
    billbrown
    not being so much tall as Wide I had to address this problem myself. Being oddly shapen is kind of shitty, but I probably shouldnt have put a stick in my truck either. WE ARE NON CONFORMISTS.
  27. Tedders
    Tedders
    At 6'5 I'm following VNCduke advice, with a 28 roadster pickup. Removed the seat and did a simple plywood cushion set up to put me lower inside.
  28. Mike Colemire
    Mike Colemire
    I want to build a "no Fender" car later on. I've been researching also. People back then must have been really short. I found a 34 Plymouth, 4 dr and was kinda thinking if I could make it a 2 dr with a small chop and have everything to look correct. This thing has good lines and a beautiful grille. Good luck, I think you made the right choice.
  29. Blue One
    Blue One
    from Alberta
    What is it with these old threads coming up ? Do you guys even look at when what you are responding to was posted ?
  30. sawbuck
    sawbuck
    from 06492 ct
    who cares about the date ,there is still good info ....
    a boner and 62hotcat like this.
